Lease End Suggestions
Willys_Wonka
PA
JLUW
I’m approaching the end of a lease and 3/36 basic warranty. Any suggestions for what to have done or mechanically checked by the dealer beforehand since I’m probably buying it? I’m also considering the Mopar Max care service plan, so is it worth it (only drive about 8k miles a year)?
Antonio
Antonio
NJ
2022 JLU Rubicon diesel
At 24 K miles +/- you shouldn’t have much to worry, I’ll post the manual screen shots, as far as the extended warranty you can ship around, plenty of forum sponsor will offer you great quotes, essentially it’s just a peace of mind policy to have cause these new vehicles aren’t built like they used to!
Tom Winkels
Hayes Jeep
3718 Stadium Drive
Kalamazoo, Mi 49008
DIRECT-269-385-1116
TEL-269.488.2080
Reach out to this person to get a quote for extended warranty, highly recommended
Jeep Wrangler JL Lease End Suggestions 424A85D3-3C69-452B-BB94-E74D0276F799
Jeep Wrangler JL Lease End Suggestions 8288773D-AAD4-48A6-AD6E-90520BC39063
Jeep Wrangler JL Lease End Suggestions 58889454-FEE0-4FE7-BFE5-FB294C0631A5
Willys_Wonka
Willys_Wonka
PA
JLUW
Tom Winkels
Hayes Jeep
3718 Stadium Drive
Kalamazoo, Mi 49008
DIRECT-269-385-1116
TEL-269.488.2080
I read that to use the Mopar Max care warranty it needs to be serviced by the same dealer that sold the warranty. Is this true? I believe in order to use the warranty elsewhere, a "request" must be made.
Antonio
Antonio
NJ
NO! You can purchase the mopar warranty from any dealers and USE it at any jeep dealer location! No request is needed, once you purchase the warranty within a certain amount of time I believe a few days you’ll see it show up in the app linked to your vin# so all dealers can also see that
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
Just remember the warranty covers “stock” systems. If you are, and plan to remain, basically in stock configuration it’s not a bad idea. If you are heavily into modifications, not so much.
I run a “stock” Jeep size tire (albeit larger than came on mine), have aftermarket bumpers, some skids, winch, and a wireless break away switch for my RVI brake. Remainder is OEM. I’m confident my extended warranty will cover any factory Jeep system that may prove problematic.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
This isn’t exactly true. To clear up any confusion, the dealer performing the repairs under the extended warranty must obtain prior authorization from the company in order to service the vehicle. This is for warranty repairs, not maintenance.
Willys_Wonka
Willys_Wonka
PA
JLUW
App, do you mean Mopar.com? That’s where I can see all of my services ever done and recalls on my jeep. Is there also an app for that?
Willys_Wonka
Willys_Wonka
PA
JLUW
I’m mostly considering the mopar max care for electronic coverage.
Antonio
Antonio
NJ
that’s not what was asked
“ I believe in order to use the warranty elsewhere, a "request" must be made.”
Clearly all warranty work needs an approval from the company that they will cover the cost to the dealer
mwilk012
Oklahoma
Service
I make these requests regularly, the customer needs to do nothing but it’s important to understand that denial of service regardless of the issue can happen and it be referred to the selling dealer.
Antonio
Antonio
NJ
They also have apps you can use on your phone
My mopar or jeep app you’ll have a garage which shows your vehicle and info
Willys_Wonka
Willys_Wonka
PA
JLUW
An example would be you buy the warranty from a local dealer then move out of state. Assuming the warranty can be used at another dealer where the owner is now located.
Willys_Wonka
Willys_Wonka
PA
JLUW
Tom is very nice and professional, I spoke with him a few times.
mwilk012
Oklahoma
Service
Absolutely not a problem. The problems come when the different dealerships are relatively close.
