AllJumpStyle
The only reason I am responding again is because people trust what manufacturer's say on this forum, and someone needs to speak up when they are being fed a load of ****.It is simply a fact that threaded members need to be preloaded. The threads on your joint, our joint or any other joint are taking axial load. The mating threads wether it be an adjuster sleeve or threads in an arm need to be preloaded for proper structure. We chose jam nuts because the structure of the assembly is greater than that of a pinch bolt setup. If you feel your setup is sufficient that is great, but we go for the ultimate in structure. Considering the loads and what is at stake for control arms and track bars, we feel the ultimate in structure is best suited.
I respect Rock Krawler and I respect the products they make, but this marketing nonsense has nothing to do with sound engineering practices. This industry is big enough for all of us, you don't need to go around trying to trash everyone else's products to prop yours up.
