Key for manual door locks
jimf5
pahrump,nevada
2024 wrangler sport, 2023 jeep renegade
Hi all
I have a 2024 JL with manual door locks. I would like to know the technical name of the of the kind of key and if it is available to be reproduced by a locksmith. I would like to get one made and put it in a Hide-a-key in case of a locked in the Jeep mistake i ALLMOST made last week.
Thanks in advance for any help.
JIm in Nevada
Ormond Beach, Florida
Retired at 55 ..
@jimf
2016 Jeep Fiat High Security Emergency Key is the blank you need if you are not needing a key blank that will work with the stock JL/JT key fob.
For those that want to buy a key blank that works with the factory fob, Threedom aftermarket Model S and Model S+ fobs and also any of the Threedom custom key holder's...... here is a place to buy the blank.
https://www.carandtruckremotes.com/...bsZyVb2O-6TAVCkB_EdLoIYJN-V1oO55jIBwuc9BGJeGM
Read here: https://www.jlwranglerforums.com/forum/threads/fobless-key.9256/
Also... Read through this whole thread. The info you seek and more is in that thread.
https://www.jlwranglerforums.com/forum/threads/?-fob-101-know-thy-jl-key-fob?.88719/
Not all locksmiths can cut, so call around and ask..
Heimkehr
Pennsylvania
2021 JLU 2.0T
@jimf5
This key blank has confirmed compatibility. It's what I carry as an analog spare for my Sport. Note that it's not the same blade, so to speak, that is currently bundled in the key fob.
A locksmith capable of router cut keys can use your existing key as a template when cutting the new one. Expect to pay a few dollars more for this service (I paid $27), vs. having a traditional key cut.
linux_guy
Alabama
2020 JL 6-speed manual, 2011 Compass 5-speed manual
When I built my gas cap lock, I documented the pin numbers and where used thinking I would skip the trial and error method of building if ever necessary again. I bet with that information alone, a key could be cut to spec. I realize the key transponder is another moving part.
jimf5
pahrump,nevada
Hi All: I got two blanks but no one in my town can do it. Only two locksmiths in my town one says no can do and the other one is a mobile one, with no storefront, and charges $50.00 just to come out too see if he can and then see what he will charge . Hell no!
I live 45 miles west of Las Vegas and found one who charges $75.00 per key, but he works with Tipple A and told me to go there and fill out the form for reimbursement and i will get
$100.00 back, so i will only be out $50. So $25.00 per key. I made some holders for the keys and they work well are securely hidden on the Jeep.
Thanks to all for your help
JIm in Nevada
hoch
Hoch
UT
2018 JLUR 6-sp
@jimf5 - Did you check with a dealer? I had one of my local dealers cut a key for me for the same purpose. The one closest to me didn’t have the tools so had to drive ~30 minutes to another dealer. They charged me $5 per cut!
I used a @Threedom key holder and put it in a magnetic box under the Jeep.
