JL Off-road Flag Mounting
Jasper71
Jason
Michigan
2021 Unlimited Rubicon
Hello All,
Mounting an off road flag to your front tow hooks may have been a simple task for some. However, it took me a while to find a system that worked and being a new member here I wanted to share this to hopefully save someone an exhaustive search
For JL Rubicon Wranglers (Stock Tapered Front Tow Hook Shape) I found this set-up, works pretty good. It will scrape the red paint on the tow hook by the u-bolt, but you can buy touch-up paint if it bothers you:
* Flag Mount, 90 Degree Twist90 Degrees: https://www.amazon.com/Mount-Bracket-Degrees-Dunebuggy-Beetle/dp/B07H8F4DFD/ref=sr_1_1?dchild=1&keywords=Flag+Mount%2C+90+Degree+Twist90+Degrees%2C+Compatible+with+Dune+Buggy&qid=1621641418&sr=8-1
* Flag Pole Holder: https://www.amazon.com/Tusk-Quick-Release-Holder-Black/dp/B0039O6G7U/ref=sr_1_1?dchild=1&keywords=Tusk+Quick+Release+Flag+Pole+Holder+5%2F16%22+Pole+Black&qid=1621641480&sr=8-1
* Flag: 10 ft. Solid Orange Safety Flag with 2 Pc White Pole and Mounting Bolt https://www.amazon.com/Solid-Orange-Safety-White-Mounting/dp/B00E4FU65Q/ref=sr_1_1?dchild=1&keywords=10+ft.+Solid+Orange+Safety+Flag+with+2+Pc+White+Pole+and+Mounting+Bolt&qid=1621641548&sr=8-1
* Tow Hook Touch Up Paint (If you want) Dupli-Color Scratch Fix Touch Up Paint Flame Red PR4 https://www.autozone.com/paint-and-body/touch-up-paint/dupli-color-scratch-fix-touch-up-paint-flame-red-pr4/460571_0_0
Hope this helps! :)
AdamG
Adam
SE Michigan
2019 JLSportS
Resurrecting an old one…
I have the bracket and quick disco like Jasper above, but wondering if anyone has anything negative to say about using a set up normally for a bike and mounting like this? It’s super solid, and leaves both front row hooks free. I assembled it to full length and made it whip, just bumps up against the top back edge of the soft top
Jeep Wrangler JL JL Off-road Flag Mounting 84941833-6702-4183-83CD-C71840D64B65
  • Like
Reactions: J0E
AdamG
Adam
SE Michigan
2019 JLSportS
Some places require the flag to be on front of vehicle.
Understood. Rocks and Valleys in Michigan only requires you have one, and it has to be 2ft above the highest point if the vehicle.
  • Like
Reactions: J0E
Whiskeybiskit
Donny
Las Vegas
2019 JL wrangler sport s
I used a cb antenna bracket for the fender, a tusk quick disconnect flag holder bolted to that. I glued some garage floor oil mat stuff to the bracket to protect the fender and hood from scratches.
Jeep Wrangler JL JL Off-road Flag Mounting 20220828_141716
XJfanatic
Indianapolis
2020 JLU, 2020 JT, 1990 Mustang
I used a couple of unistrut brackets covered in a bike inner tube. Takes 30 seconds to remove if necessary for recovery.
  • Like
Reactions: J0E
AdamG
Adam
SE Michigan
2019 JLSportS
Jeep Wrangler JL JL Off-road Flag Mounting 762F2A29-5C47-4833-B8C3-8CF2C828F196
Did you attach it to one of the fender bolts, or at the air intake?
AdamG
Adam
SE Michigan
2019 JLSportS
Follow-up - bracket and zipties 100% works, everything stayed connected. Bracket will now stay on, it is rock solid and no need to cut it off. Another guy bought the same bracket and screwed it to his front bumper, also worked. So $10 for a flag and mount, not bad. If I go somewhere that requires a front mount, I’ll address it then.
  • Like
Reactions: J0E
Cheapjeep
Lucas0706
Jeep Wrangler Sahara
I used a couple of parts I found in the electrical department at Homedepot. I put a bolt through an existing hole in the frame. I used a magnet to hold the washer and nut in place while screwing the bolt. Works great!
Jeep Wrangler JL JL Off-road Flag Mounting 6E2AB51E-0397-44B5-9648-1F20FE6304EE
Jeep Wrangler JL JL Off-road Flag Mounting 413937F2-13B6-4823-BADA-3037E9D778DA
Jeep Wrangler JL JL Off-road Flag Mounting 8FC647C4-3453-4696-9CE1-CFE2F28509C7
Jeep Wrangler JL JL Off-road Flag Mounting 770E9C51-15A4-4AD8-A552-DEC61C2274ED
Jeep Wrangler JL JL Off-road Flag Mounting 380A3186-56A3-47E0-8F74-924717361F37
  • Like
Reactions: J0E
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
I know lots of places require a flag, none of them require a front flag. I'll be sure to do my homework when planning any trips. To be safe, add a mount in the front in case it's required.
