JL Door Weight
swozey
Denver, CO
What's up with the pins? Do you screw them in to the doors hinge and you can lift the door right off the hinges with no unscrewing at all? I have heard of doors getting stolen :(
TheNewGuy
Wes
NH
If the door is closed, it can't be removed
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
You can leave them on full time. Unless you are upside down with door open its not falling off. Doors locked no one is taking your door. If anyone wanted your door and it was unlocked, they could unscrew bolt in 60 secs and take your door.
Main use of the pins is they help you slide door back on without worrying chipping hinge paint from the sharp screw left exposed.
Jeep Wrangler JL JL Door Weight 1657202241669
Jeep Wrangler JL JL Door Weight 20220531_141609
TopGunViper
MO
2021 Jeep Wrangler Rubicon Unlimited
Is everyone using two pins per door?
Is the lower pin the same size as upper?
TopGunViper
MO
Can you install these with the door still on the hinges or do you have to take the door off before you can install these?
patternman
George
Phoenix AZ
2019 JLUS, 2014 & 2001 Indian
I use 2 pins per door. they minimize risk of scratching paint and make alignment much easier when rehanging the door.
I took my doors off to install one might be able to install with doors on but I didn't try that approach.
