JL Door Weight
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
Thanks!! I'll be getting some of these now as well, ha.
Your Jeep looks like Sting Grey? My wife's Sahara is Sting Grey. Changings colors different light.
It has the power top. I like it but I went with the Hardtop on my Rubicon.
Not sure what you will be using to remove the top but the TPL is nice to have. I love mine. Easy to remove and store.
Jeep Wrangler JL JL Door Weight 2019 Jeep JLU Sahara  Lifted 33's  now
Jeep Wrangler JL JL Door Weight EFFECTS001_1585775251626_001
Jeep Wrangler JL JL Door Weight Panels off with Half-doors 3
Jeep Wrangler JL JL Door Weight 20210319_105627
Jeep Wrangler JL JL Door Weight Naked
Jeep Wrangler JL JL Door Weight TPL
DJP1812
Dominick
FL
'22 Jeep Wagoneer, '22 JLUR 4xE
Love the Jeeps! Thanks!! I've been getting a ton of ideas the past 4 months as mine was being built. I have a Sting Grey with the SOT top. Figured I'd give it a go since it was new and I've had a soft top before. Convenience can't be beat, but still getting use to it.
I've pretty much got a lot of the small stuff ordered, installed, or on a list. It's time for tires, wheels... and the bigger $ items.
My wife drives the Wagoneer. So nice! Way to big, ha.
NewJLU2019
Curtis
Yea I liked the SOT but just couldn't get used to how it looked even with the side panels off.
I couldn't keep her out of it so I retired early and let her have it and got my Rubi.
My son lives in Florida so I know how the pop-up rain showers can hit you anywhere. The ease of closing the SOT and then open after shower passed is nice.
One thing I found out quick in Texas is that black top is very hot parked in Texas sun very long.
But would open top while AC starting and let hot air out then closed.
I have been using this. Its made for the Twill top. Looks brand new still. Bird poop wipes right off.
I really soaked top 3 times first year. Wanted a good coat to start with.
Congrats on your Jeep !!! Lot of info and really nice Jeepers on forum.
Bestop Black Twill Protectant is uniquely formulated to clean and help protect super-premium black and color twill acrylic fabric like that used on Bestop Trektop Pro or the optional premium soft top option on factory Wranglers.
Repels Dust/Grease/Dirt And Mildew
Contains No Destructive Silicone/Petroleum Solvent
Protects Against UV Fading/Cracking And Hardening
Easy Application
16-oz. bottle
Jeep Wrangler JL JL Door Weight 1654035718273
Jeep Wrangler JL JL Door Weight 1654035657353
DJP1812
Dominick
FL
THANKS! I was actually curious how to protect that top. Ill look into it! FL sun destroys everything.
[DELETED USER 82058]
Alabama
2022 JL Rubicon 2-Door
Jeep Wrangler JL JL Door Weight 208010D4-6571-4E52-A3DE-D0BEBEFC3CC3
I bought the pins from TMR Customs. They are are black and made of Delrin. I put a pin on the upper and lower hinge which defeats the guidance purpose but does protect the paint. The door weight felt heavier than my JK but as someone already pointed out, it’s actually lighter. My biggest issue was putting them on, my driveway is slanted, I’m out of shape and it was 90 degrees the other day so my hands started sweating and slipping a bit. It’s awkward putting them back on but really awkward at a slant. Best thing to do with the door bolts is drop them in the storage slots in the back and forget they came on the Jeep.
Packnbeer
Jamie
Davenport, Iowa
2021 Jeep Wrangler Sport S 2-Door
I concur - 25 to 30 pounds. Very easy to handle. I also agree that door pins are amazing! makes door handling MUCH easier
Zenmaster238
Jonathan
Louisiana
2022 Firecracker Red JLURXR
any concerns about doors flying off if you are ever in an accident?
Alabama
I’m under the impression that they can’t be that much help. I mean if you have them off and go flipping down the road vs them bolted on, maybe they help a little? I just don’t depend on them to help me. I rely more on the roll cage and seatbelt.
Buster1
Ft Worth, TX
‘51 M38
Sorry for the thread drift, but can you guys explain HOW the door hinge pin bolts protect the paint?
I keep hearing this, but not sure I understand. Is it more from using a ratchet on the original bolts and hitting the paint? Or is the problem in dropping the doors back into the hinges?
Thanks!
NewJLU2019
Curtis
Thanks!
I'll chime in. Once you remove the factory bolt you screw off and you can feel how jagged and sharp the ends that you screw onto are.
The pins are shaped like the end of a bullet and are smooth. I find it so much easier to guide them and let them slide down without worry about the sharp edges knocking the hinge.
They are stainless steel. I just leave mine on for both sets of doors. The tube door is not very close up pic.
Jeep Wrangler JL JL Door Weight 20220531_141609
Jeep Wrangler JL JL Door Weight Naked4
NewJLU2019
Curtis
Thx! Makes sense.
love your rig BTW!!
Thanks, once you remove the factory bolt from door hinge and remove door you will see the end you screw onto is sharp and jagged. I can see why others have said it knocks chips off hinge.
Amazon $17.99
Jeep Wrangler JL JL Door Weight 1656958551855
Voodonala for Jeep Door Hinge Pin Bolts Guides Liners Stainless Steel Antidust Rushproof Kits for Jeep Wrangler JK JKU JL JLU Sports Sahara Freedom Rubicon Unlimited & Gladiator JT 2/4-Door,8pcs
WhereRU_A-A-Ron
Aaron
Arkansas
2021 JLU Willys, 2023 Ford Expedition Stealth Edition, 1968 Mustang Coupe 289
Business Director
They are not that heavy. One person has no issue removing them. Front doors of course little more weight.
May I suggest you purchase Door Pins for they make it so much easier to remove and put doors back on without chipping the paint on your hinges. I leave mine on all the time.
I use set for half-doors too.
https://www.amazon.com/Hinge-Guides...875239&sprefix=Jeep+door+pins+,aps,186&sr=8-4
I just got these in today and installed them. I'm certainly less nervous now about scratching the Jeep when I put the doors back on. One question though; should some of the thread on the top pin be exposed after install? I assume they should since the top pin is much longer but just want to be 100% sure.
Jeep Wrangler JL JL Door Weight IMG_4090
NewJLU2019
Curtis
Yes, just like mine. I know it gives my peace of mind lower pin into hinge. I really like mine.
