JKU turn signal gremlins...
jfb118
jfb118
Low Country
2015 JKU Rubicon Hardrock
I just had an issue turn up with my left turn signal. All other lights are working correctly.
When I start the Jeep, all is normal, all the dash lights come on an cycle off as normal.
When I use the LEFT turn signal, it works correctly for about 10 to 20 seconds, then I get a message in the info area that the left turn signal bulb is out and the flashing rate doubles.
The right turn signal is fine.
The message and issue stays until the Jeep is shut off.
When I start the jeep again, the cycle repeats, no issue until the left turn signal has been on for 10 -20 seconds.
The left turn signal bulb is fine, since it works fine on startup, and for the first 20 seconds. I did replace t hat bulb with the spec 3157 and no change, still the same problem.
ANY suggestions are welcome...
kah.mun.rah
Merenkahre Jr.
Duat
Did you check both the front and rear turn signal bulbs?
alphawolff
california
2021 JLU
Replace all the bulbs on that side anyway. It uses voltage drop to determine if a bulb is out, so one that's slightly out of spec will cause the issue. Don't forget the peanut bulb in the fender
jfb118
jfb118
Low Country
Thanks for the suggestion, I will order another pack of 3157s and replace the other two bulbs.... I'll let you know if that does it
jludave
The Isle of Long
IT Manager
Terrymo
Terry
2023 JLURXR 3.6 ET
Swap the bulbs one side for the other and see if the hyper flash follows the bulb?
Blckdog
Kevin
Connecticut
2023 Willys JLU
Just went through this with mine after switching to high rise flares. Exact same issue. The remedy was clear everything to factory setting a reprogram from the start factor fresh with the JSCAN.
This was th only way to get everything worked out.
Mine is a 2023 but it probably works for a JK too.
Good luck.
