Jeep Order Tracker - Open to Join
Tk71107
Shawn
Buford Ga
2024 JTR
Still getting this error even after changing browsers, different devices, and just typing in jeeptracker.com
Pizza tracker does show my build so I know the inputs are valid.
Microsoft OLE DB Provider for ODBC Drivers error '80004005'
[MySQL][ODBC 3.51 Driver]Access denied for user 'ndrugby_jeep'@'192.185.6.22' (using password: YES)
/addjeep.asp, line 37
Captain Tuttle
PA
2023 Toyota 4Runner Limited, 2023 Jeep Willys
Been like that for me since Nov 2023 when I placed my order. I don’t use this one anymore.
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
That's on error on the server, won't matter which browser or device you use ... and it's also giving away valuable security info :facepalm:
dseffren
Fort Mill, SC
2024 4xe Willys, 2021 Willys
I’m getting an error. -
“Microsoft OLE DB Provider for ODBC Drivers error '80004005'
I’ve created my own Jeep Tracker for anyone with an order. A few people on here volunteered to help me test it and I think it’s pretty stable now. Thanks volunteers! Here are some details:
What Is It?
It’s an application I built to check the status of ordered Jeeps using publicly available data. The statuses it can check for are:
C- Order Confirmed
D1 - Scheduled
E - In Production
KZ - Built
KZM - Shipped
KZX - Delivered
As far as I can tell these are the only publicly available statuses. Your dealer can give you updates on other statuses like D or some of the other build and shipped statuses.
Here is a screenshot of my app (only my access, not visible by others)
How does it work?
It checks your VON and Last Name against data that is available on a regular increment (every 5-15 minutes). If there’s a change in your status, it emails you. Also if you’re at a stage where you should have a build sheet or window sticker, it will create links for you. I am adding code to check those and make sure they exist. Right now I’m assuming when they should be there. Here is a sample update email.
How is it different from the Pizza Tracker?
The data available is the same. But it checks for you. And in some cases it has updated before the Pizza Tracker. In other cases it updates at the same time.
What does it give me?
A Webpage where you can check your status without having to enter your VON and Last Name. You’ll have your own link. Looks like this:
Also, there is a daily update email (that you can turn off if you want) that tells you how many times it checked, how many changes it found and how many emails it sent you yesterday and all time. That looks like this:
Why did you build this?
I wanted a way to get updates on my Jeep without checking all the time and I like to build software.
I’m just a guy that loves Jeeps. I ordered a 23 to replace my 12. I built a similar system back then, but there was more data available. You could track every movement. I don’t work for Jeep and I don’t have any insight beyond what I show you.
How do I join?
Go to Jeep Tracker, click on Add Your Jeep to the Jeep Tracker. And then fill in your VON, Last Name, Email Address and choose whether you want the Daily Update email(you can edit this later).
It may take up to 5 minutes for your Jeep to register in my system. But that page will give you your custom URL to check status (you can also go to the home page and enter your von and last name to check status).
What else should I know?
I’m just opening this up now. So there could be errors or issues. Not sure how it will handle hundreds of Jeeps, but I’d love to find out. I’ll keep working to fix issues. So if you have a problem, please DM on here.
Good luck with your orders everyone and I hope you enjoy my Jeep Build Tracker.
