JEEP JLU Rubicon Power Steering Fluid
SnowHunter
Snow
Cambodia
Jeep Wrangler JL Unlimited Rubicon 2023
Hello everyone, hope you all doing amazing.
Any help is appreciated.
First time owner of JEEP Wrangler Rubicon Unlimited 2023. I been doing some diy work on my car to save on expenses since the dealer ship charge quite a bit.
During my last visit at the dealership they said I need to top up my power steering fluid and coolant.
I make a mistake of using the wrong type of fluid. I use Mopar power steering +4 instead of the recommended one in the owner Manuel (Mopar electric power steering fluid) FYI. I couldn’t find the owner Manuel so I did Google search during that time
it only a small top and I been using the car for a few month now. It’s show no sign of any issues. So should I flush out the power steering fluid or just add the correct one next time?
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
It's the wrong fluid, you should have flushed it out a month ago.
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
That really should not be low unless you have a leak. Need to find that
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Ehh, these things use like a quart of fluid and small seeps show as a drop in level that aren't worth repairing. Topping it off every oil change is perfectly fine.
OP, yes, get that shit out of there.
zakaron
Pittsburgh, PA
2021 Willys 4dr, 2004 Pontiac GTO, 1986 Honda Nighthawk S
The Mopar power steering +4 is compatible with their ATF +4. CHF electric power steering fluid is not compatible with any ATF, so my vote is to flush and fill with the correct CHF fluid. @Bandit59 brings up a good point, if you are having to frequently top off, then find the leak as these are sealed systems and not supposed to use any fluid. At $40 a quart, it can be an expensive leak to "top off" over time. Yeah, I was a bit sticker shocked when I saw the cost at the parts store myself...
SnowHunter
Snow
Cambodia
thank for the reply
Will do a flush and monitor the level if it drop again. The recommended top up was the first time visit after I got the car. So let see if there an actual leak or they didn’t top it up before they give me the car.
I did some googling and couldn’t find a proper video to flush for JEEP JLU. I watch a few similar video, so do I need to drain out the fluid from the power steering pump also or I only need to drain the reservoir. I couldn’t find the information in the owner manual.
Also if anyone owner a JEEP JLU and know what the power steering look like a picture would be helpful
