Jeep 392 Upgrades :)
JustinB
JustinB
Arkansas
Jeep Cherokee, Ninja 650R, Jeep 392, Yamaha TTR230
Finally!!! Got the doors off :like:
EbyCreek
Troy
Eagle, Colorado
2021 Wrangler 392
ARMY (Retired)
Removed the Wrangler Unlimited stickers and put on some factory 392 emblems. What do ya think???
Jeep Wrangler JL Jeep 392 Upgrades :) j11
Where did you get the 392 emblems? Everyplace I look it says not available.
JustinB
JustinB
Arkansas
I ordered them right from the dealer like back in June. There are two different part numbers, one for the left the other is for the right side of the hood. The pins on the back align differently for each side which I didn't know so my right emblem was on back-order for months when I could of just ordered two left side emblems. I ended up cutting the pins off the back anyways....
JustinB
JustinB
Arkansas
Hood Locks:
I installed some DV8 Hood Locks, Firecracker Red color matched.
Certainly not 'theft proof' but it may slow em down a few extra seconds. Also, I think they look pretty cool :like:
JustinB
JustinB
Arkansas
DV8 Front & Rear Inner Fenders Jeep 392.
This install ended up being a bit more difficult than any of the videos I watched regarding the install of the inner fenders alone, of course there were no instructions. I'm very glad I did test fit prior spraying the inner fenders or I could have ended up scratching the paint job quite a bit. It took a lot of finagling & some customizing and the use any of the Christmas Tree push pins to hold these in place was a No-Go for me. Perhaps this set was for a non-392 JLU.?. Now with that I did invest extra time time customizing these inner fenders to my liking.
These inner fenders were originally vented, and still kinda are, just not as much now. I love the vented look but I do not like the idea of water splashing up in the engine compartment every time it rains, or sand, dirt, etc... So, I built a back plate that sits about a half-inch behind the drilled grill [using nuts as spacers] that still allows for water/sand drainage and of course allows for vented air passage. The plates are about a half inch larger on all sides so air can still vent thru the sides but we're not dealing with the same degree of contaminants. I also sprayed the backplates with chrome flake [and clear-coated the plates] so there's some bling when the sun hits. It's not over-the-top bling but definitely a nice little accent that goes with the wheels. More specifically, I used regular galvanized sheet metal for shape integrity and put the same-sized cosmetic aluminum sheet metal over that, liquid nailed the two together, then after drying I drilled the bolt holes. The cosmetic sheet metal has a shiny textured look and this is what I sprayed the chrome flake on.
I also installed some rubber to cover the now exposed areas under the front fender that would otherwise be exposed to the elements and allow dirt build-up if only the new inner fenders were on, besides it's kinda unsightly to see what would normally not be covered, the underside of an exposed fender. There are some electrical connections and a box below the right fender as well. Not sure what the box is for but it's electronic.
I may use rubber on the rear fenders but as it is now it does not look too bad, I do want to replace the rear white fender clips with black clips which I already have, just not installed yet. The front clips are not seen due to the installation of the rubber.
If anyone plans on installing DV8 inner fenders on a 392 feel free to reach out. There ARE some things you should know that'll help with the install, primarily where to drill into the frame to ensure a secure fitment, no Christmas tree push clips allowed ;) And if you have a cute helper with little hands that's a bonus! :rock:
Jeep Wrangler JL Jeep 392 Upgrades :) 20211025_123921
Jeep Wrangler JL Jeep 392 Upgrades :) 20211025_123907
Jeep Wrangler JL Jeep 392 Upgrades :) 20211022_143403
Jeep Wrangler JL Jeep 392 Upgrades :) 20211022_143441
Jeep Wrangler JL Jeep 392 Upgrades :) 20211007_172043
Jeep Wrangler JL Jeep 392 Upgrades :) 20211007_172155
Jeep Wrangler JL Jeep 392 Upgrades :) 20211007_172227
Jeep Wrangler JL Jeep 392 Upgrades :) 20211007_172252
Jeep Wrangler JL Jeep 392 Upgrades :) 20211009_152336
Jeep Wrangler JL Jeep 392 Upgrades :) 20211009_152341
Jeep Wrangler JL Jeep 392 Upgrades :) 20211009_152346
Jeep Wrangler JL Jeep 392 Upgrades :) 20211009_152351
Jeep Wrangler JL Jeep 392 Upgrades :) 20211009_152357
Jeep Wrangler JL Jeep 392 Upgrades :) 20211012_170237
Jeep Wrangler JL Jeep 392 Upgrades :) 20211012_170243
Jeep Wrangler JL Jeep 392 Upgrades :) 20211012_170250
Jeep Wrangler JL Jeep 392 Upgrades :) 20211012_170310
Jeep Wrangler JL Jeep 392 Upgrades :) 20211012_170317
Jeep Wrangler JL Jeep 392 Upgrades :) 20211012_170327
Jeep Wrangler JL Jeep 392 Upgrades :) 20211016_134330
Jeep Wrangler JL Jeep 392 Upgrades :) 20211017_125704
Jeep Wrangler JL Jeep 392 Upgrades :) 20211017_125737
Jeep Wrangler JL Jeep 392 Upgrades :) 20211017_135011
Jeep Wrangler JL Jeep 392 Upgrades :) 20211017_134821
Jeep Wrangler JL Jeep 392 Upgrades :) 20211017_134845
Jeep Wrangler JL Jeep 392 Upgrades :) 20211017_134853
Jeep Wrangler JL Jeep 392 Upgrades :) 20211017_135147
Jeep Wrangler JL Jeep 392 Upgrades :) 20211017_161731
Jeep Wrangler JL Jeep 392 Upgrades :) 20211017_161755
Jeep Wrangler JL Jeep 392 Upgrades :) 20211020_182012
Jeep Wrangler JL Jeep 392 Upgrades :) 20211020_182020
Jeep Wrangler JL Jeep 392 Upgrades :) 20211020_182033
Jeep Wrangler JL Jeep 392 Upgrades :) 20211021_095447
Jeep Wrangler JL Jeep 392 Upgrades :) 20211020_182038
Jeep Wrangler JL Jeep 392 Upgrades :) 20211021_095452
Jeep Wrangler JL Jeep 392 Upgrades :) 20211022_100259
Jeep Wrangler JL Jeep 392 Upgrades :) 20211022_100309
Jeep Wrangler JL Jeep 392 Upgrades :) 20211022_143516
Jeep Wrangler JL Jeep 392 Upgrades :) 20211021_164327
Jeep Wrangler JL Jeep 392 Upgrades :) 20211021_164337
Jeep Wrangler JL Jeep 392 Upgrades :) 20211021_154852
weeitsmikelee
Durrty Jersey
‘21 Wrangler392; ‘20 F-Pace; '15 XL883N; '82 CX500
Healthcare
The painted visors contrasts nicely to the weather stripping. It looks like it belongs there 👍🏼
Wish we just got a badge under the tail light instead of two on the hood. Even under the Jeep logos would’ve been better.
FloridaLarry
Larry
Boca Raton, FL
Rubi 4xe
IT Manager
It's been a few weeks since I bought her. What's been done thus far...
Removed hardtop (stowed in garage) put on soft top.
Wheels n Tires (decided on the chrome wheels).
Tinted windshield (silver) and front side doors (20% black).
Automatic electric step rails (raise/lower when the doors close/open).
Spare tire tailgate mount to compensate for the larger tire.
Bad a$$ alarm, no details
Still to do...
Upgrade the stereo.
Spray the mirrors, tail light mounts, n door handles to color match (a weekend project). And maybe the bumpers?
Apply a ceramic coating.
Have a Blessed Day :)
~justin
Wheels look like Grand Cherokee SRT's. Any relation?
Jeep Wrangler JL Jeep 392 Upgrades :) 1635187163883
JustinB
JustinB
Arkansas
They are brothers! LOL
That's what I have, OEM Replicas to the SRT. How could I go wrong, lol. They also have these wheels in a black chrome [which may be what's on the Grand Cherokee, hard to tell.?.]. I was torn on which to go with, obviously I went with the chrome. Mine are 20x9. Perfect fitment to include perfect hub alignment where the hub & wheel 'slide' together.
JustinB
JustinB
Arkansas
I appreciate it, thank you. Ya, like most projects I try to imagine what the final product will look like, like most people - I assume. With this one here though I sensed it would either go really well or end up looking cheesy & cheap like it just didn't belong. I had some people telling me to not paint them at all.
Unlike the inner fenders, with the visors being so close to the factory paint it would have to color & texture match perfect which included wet sanding & polishing them. Now I just need to figure out what to do with that little window on the rear doors.?. I'd like the visor 'lines' to match all the way down the side. I'll figure something out.
JustinB
JustinB
Arkansas
JustinB
JustinB
Arkansas
An Excellent Investment, the TAZER Mini!!!
As I have slightly oversized tires (from stock 33 to 35") this the primary reason I purchased a Tazer Mini. I'm sure some of you have heard of this device, but if not... This device 'reprograms' the vehicle's speedometer and shift points when plugged into the Security Gateway Module (SGW) located just above/behind the OBD port.
As an example... Prior the Tazer Mini install while having my oversized tires on, when the speedo says I'm going 80 mph in reality I was doing ~ 88mph. However, this little gadget does much much more. (From their website [Zautomotive] I'll copy/paste some of the other functions below.)
But real quick.. it does have a function to disable the front wheel drive, or rather, have only rear wheel drive on, so, I had to try it. On a back street at a dead stop I romped on the gas and Holy $hit!!! I started to roast my tires as the 392's ass end dropped! Now I only did that just once to witness a Wrangler actually doing a burnout, and a hell of a burn out it was!
With that, I would not recommend leaving that setting on. Maybe give it a quick whirl to witness the same as I, a Wrangler roasting the tires, LOL. I can only imagine doing that frequently would ultimately snap something in the rear end - it's simply too much torque. For race, the 392 launches much quicker in 4 Auto, but it's still pretty cool to see.
https://www.zautomotive.com/product/z_tzr_jlm/#camera-kit
WORKS ON ALL VARIANTS OF THE JEEP WRANGLER AND GLADIATOR
Tazer JL Mini is to be an essential tool for owners of the 2018+ Wrangler JL and Jeep Gladiator. All engine and transmission variations supported, including export models.
Simple, plug-in installation – simply unplug the SGW module and plug the Tazer JL Mini in its place. Located above the OBD2 Diagnostic connector. To make it easier for removal and reinstallation for dealer visits, add on our SGW Extension Cable.
Features are all accessed using the dash display, using steering wheel buttons to navigate the menus.
Tazer JL Mini features can be broken into two categories;
Vehicle Settings – which are changes made to the Jeep like tire size, gear ratios,
or change settings to accommodate other upgrades or modifications. These
changes will continue to operate after the Tazer JL Mini is unplugged.
Live Functions – which are functions the Tazer JL Mini performs live, only while
plugged in.
Vehicle Settings:
– Change Tire Size
– Change Gear Ratio
– Change Transfer case LOW ratio
– Enable/Disable TPMS system
– Change TPMS pressure warning limit front/rear (25psi-85psi)
– Enable/Disable Backup camera
– Enable/Disable Cargo Camera input (8.4 Uconnect only)*
– Enable/Disable CD (wired audio) input*
– Enable/Disable TravelLink/XM traffic&weather
– Change Daytime Running Lights (DRL) region (type)
– Change DRL location
– Enable/Disable DRL Dropout function
– Enable/Disable factory fog lights
– Enable/Disable Fog Light Dropout (when Fogs shut off while High Beams are on)
– Enable/Disable Factory Halo lights (including BCM output for adding Halo’s)
– Enable/Disable One-touch lane change
– Change Headlight type (std/LED)
– Change Fog light type (std/LED)
– Change Taillight type (std/LED)
– Change Front Turn Signal type (std/LED) – supports aftermarket LED lights too
– Enable/Disable Trailer Tow setting
– Enable/Disable Aux Button settings
– Enable/Disable Blind Spot detection (if hardware added or removed)
– Enable/Disable/Change Parksense configuration
– Disable Electronic Sway Bar (if removed from vehicle)
– Disable Front Axle Disconnect module for axle swaps
– Disable Front and Rear Lockers for axle swaps
– Disable Electronic Steering Pump for hydraulic steering conversions
– Change cluster splash screen Wrangler/Sahara/Rubicon
– Change HVAC controls setting to allow use of dual zone controls on single zone Jeep (for those upgrading the 5″ radio)
-Enable HomeLink for those that add the Homelink Visor and harness
-Enable Proximity Entry for those that add the door handles and harnesses
-Enable 115v bed outlet for those that add the hardware on Gladiators
-Enable Automatic Headlamps (If hardware added)
– Enable/Disable PANIC button on remote
– One-touch return-to-stock – Quick “unmarry” function returns all vehicle settings back to
stock.
Live Functions:
– AutoStopStart disable – remembers last state of the auto stop start system and will set it for
you the next time you start the vehicle
– AutoTracKill – remembers last state of traction control system and will set it for you the next
– Can disconnect sway bar in 2WD up to 30mph (any speed if button mapped SwayKill is used)
– Can use backup camera and added cargo/front/undercarriage camera or media player at
any speed
– TurnCAM – automatic backup camera when turn signals are used (8.4 uconnect only)
– Dark Mode- Turns off all exterior lighting and dash/radio/shifter lights while parked with
engine running.
-3rd Brake Flash – Set rate and number of flashes to pulse the 3rd brake light when brakes are applied for increased visibility
– Light Show mode – 6 preset and 3 make-your-own Light shows that flashes all the exterior
lights, perfect for car shows/first responders/off-road visibility. Control from Key Fob or
steering wheel buttons. Can be enabled for in-motion use for parades, off-road and legal
police/EMS.
– Axle Locker control (Rubicon) – Engage lockers in 2WD and 4Hi on demand.– TC Kill – Tuns off traction control, stability control and ABS.
– Hood Alarm – When the vehicle theft alarm is armed, monitors hood activity and will sound
the alarm and flash light shows if opened.
– Cooldown mode: Turn engine fans on demand when the ignition is on, engine not running
– Line Lock: Can lock front brakes for an easy burnout
– Rock Crawl: Can lock all four brakes by pressing steering wheel buttons to hold the vehicle
still, especially helpful when off-road.
– Winch Mode: Raise idle to 2000 RPM with a simple button press.
– Button Mapping: Use cruise up, down and right buttons as quick-access to some of Tazer
JL’s functions, when cruise control is off.
– Display DTC’s – Shows the diagnostic codes that’s making the check engine light come on.
– Clear CELs – Reset that pesky check engine light. Good when you have mods that set the
light and you know exactly why.
– 0 to 30 and 0 to 60 Timers – Displays 0-30 or 0-60 times on EVIC display
-Automatically blanks license plate lights when in Reverse on Gladiators, to remove glare on the backup camera at night.
-Vacuum/Boost gauge – Watch real-time Manifold Pressure, great for boosted/turbo applications
– Firmware updates – the new firmware is available periodically, always free!
Jeep Wrangler JL Jeep 392 Upgrades :) 53AE2051-CCD4-407C-95CF-3AFF9F44D534
Tazer JL Mini now has Turn Assist.
Firmware 11.3.7 - 040622
  • Added Turn Assist (lock inside rear tire for sharper turns) as a BUTTON REMAP ONLY function
TazerJLMiniUserGuide1137.pdf (zautomotive.com)
Azreed2000
2019 JLUR
Still to do...
Upgrade the stereo.
~justin
Looks good. How well do you think the windshield will hold up with the tint? I've gone through windshields in the past like water (thank you Colorado mountains during ski season) and I don't want to re-tint every time.
