Issue with Synergy Adjustable Rear Upper Control Arms
Northridge4x4
Summit Sponsor (Level 3)
Silverdale, WA
www.northridge4x4.com
2016 Sahara JKU, 2013 Rubicon JKU
Seller of badassery
We have been instructed by synergy to allow them to handle all warranties. Unfortunately we are both at the mercy of them at this point.
Ran4
Ran4
Randy
Port Saint Luce FL and Charlotte, NC
2019 Sahara Unlimited
I understand that, but at what point will Northridge take the bull by the horns? Another day or two? ..a week? ...a month? In the meantime, a loyal customer (me) is waiting an unacceptable duration of time for his parts. In my opinion, this isn't even a warranty issue. The control arms were never installed. They were faulty before departing the manufacturer. They should 'simply' be replaced with non-faulty ones. I've been told that you have another set of Synergy rear upper control arms in stock. How about going the extra mile, taking them out of the box, and testing the pinch assemblies? Then, 'assuming' they aren't faulty, send them to the customer. Testing the pinch assembly is an extremely simple procedure (see video attached to the first post of this thread topic). Maybe...just maybe, Synergy has an issue with these arms. For everyone's sake, I'm hoping that's not the case, and the faulty ones that were originally sent are an outlier. But, let's assume for a moment that Synergy 'does' have an issue with these control arms. Do you want to sell them to another loyal customer?
Northridge4x4
Silverdale, WA
Seller of badassery
I was not aware these weren’t installed I will follow up Monday
PIG
Rock Sponsor (Level 1)
SLO, CA
18' JL
It seems like a pretty simple engineering feat to not screw up. It's definitely not rocket science, and it's basically the same set-up as the OEM drag link. My main reasons for getting these arms over some of the others are (A) not everybody's arms are readily available right now, and (B) I wanted to try Synergy's dual durometer bushings.
Hey Randy, I got your arms here at the office now and will be getting you sorted and taken care of on Monday. We have seen this issue a handful of times before. It is most likely a double adjuster sleeve that got through QC that was actually out of tolerance. Again, I will get you taken care of Monday. To the other guys having "customer service" issues here at my place I would encourage you to contact me directly if anyone here reading this has any issue at all. This is my company and stand behind ALL of my gear 100%.
[email protected]
Direct: 805-706-0235
Ran4
Ran4
Randy
[email protected]
Dave, thank you for this post. I should mention here that in an effort to resolve this matter early on, Scott Jabs sent to me a new adjuster sleeve prior to my returning the arms to Synergy. As much as I was hoping the new sleeve would solve the issue, it didn't. As illustrated in the video I posted at the top of this thread, the sleeve 'does' pinch down to the point in which I was unable to turn it. But at 100 ft lbs, I was still able to easily turn the yoke by hand. I have to believe this is not how it's designed to work. This was true with both of the rear upper arms I received.
kosinar
South Carolina
2020 Black JLUR 3.0 EcoDiesel received 3/6/20
Thank you!
Word of caution. I had alignment done yesterday and my caster is 7.6 degrees. That is fine for my setup. I have total of 5” lift. If you have less, you will end up with greater number. You have to extend arm enough to make room for jam nut.
word302
Oregon
JLU
That’s way too much caster no matter how much lift you have.
DeadHead
Oregon
2020 JL Sport, 1996 ZJ Limited, 2002 Dodge Ram2500
Marine construction
[email protected]
Lol. I got a drag link with 2 bad ends you said it was a boot issue. You don't stand behind anything, you hide behind your desk.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
????? thanks for the lol
word302
Oregon
JLU
Yeah I’m not a fan of a company that tries to publicly trash their competitors in order to gain customers. Synergy won’t ever get any of my business.
PIG
SLO, CA
18' JL
Sounds like too much @ 7.6 How well is the wheel returning to center after turning while driving normally on the road?
