Is a distinct fuel smell on the trail normal ?
Ole_Robby
Robin
Lake Havasu City, Arizona
2024 RUBICON
We have taken our 2024 2 door out just a couple of times since we bought it, as work has been really challenging. We had ARTEC full skid plates installed at the local 4x4 shop shortly after it arrived.
Each time we have had it out a bad fuel smell appears once on the trail.
Each time I filled up before setting out. Both times over mountain train > 6000 feet, both times the temperature was 85 or more.
We do go slow. After going over a few rocks and a bunch of bumping back and forth the fuel smell starts. This smell does not occur during street driving.
The question is,
Is this normal ?
yokramer
Snark Incarnate
I have never smelled fuel while out wheeling, Id have to say no not normal.
John VonJeep
Middle of Nowhere
Many
I’ll occasionally get a fuel smell when I’m on a slow trail. I figure it’s some weird combination of heat, bumps, emissions, and unusual stress cycles for the engine. But I’m talking like a couple times a year. Every time? That don’t sound right.
Remorseless
NC
That is definitely abnormal.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I never smelled fuel on the trail, I would say no.
Ole_Robby
Ole_Robby
Robin
2024 RUBICON
Do you think starting with 3/4 fuel or less would be a good idea ?
John VonJeep
Middle of Nowhere
Many
I honestly don’t know. I should emphasize that it’s a very faint and passing phenomenon for me. If you’re parked and continuously smell fuel, I’d say there’s something wrong. But it could be as simple as some emissions control weirdness.
Remorseless
NC
Maybe elevation change causing it?
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
Definitely worth a try. If you’re smelling raw fuel it’s coming from somewhere it’s not supposed to. Being topped off it might be spilling out of the top of the tank somewhere that you can’t see.
Remorseless
NC
The thing that worries me is that a shop installed your Artec skids, which requires dropping the tank, and so there's no way to know if they screwed something up without pulling it apart and dropping the tank again. I definitely lean more towards it being a shop goof than anything, given the work that was done.
Ole_Robby
Ole_Robby
Robin
2024 RUBICON
I suspect that his might be the case. I will head down there today and have a talk with them...
yokramer
Snark Incarnate
You should never be smelling raw fuel outside of a gas station in a newer vehicle. There is something wrong somewhere along your fuel and/or EVAP systems. Go get it looked at.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Agree, re: Smelling raw fuel in any circumstance, or use case, requires investigation and resolution. I don't even smell it during or after vigorous riding on the dual sport, which has the simplest fuel delivery configuration possible.
Possibly it's something as simple as the Jeep's tank being topped off, which you shouldn't ever do.
ForgottenTaco
CT
ā€˜23 Sarge Green JLU Willys
Interesting. 2 threads from 2 different people about smelling fuel.
