Remorseless
- May 10, 2022
- NC
- '22 JLR 2.0T, '24 JTR, '19 Charger R/T
- Build Thread
- Link
- Occupation
- Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Guy Who Defines What A Jeep Guy Is
I had the same thought, but it's much lower RPM than a normal startup would be dry. And when you start it up after running the crank procedure it's SO much quieter than normal. In my 2.0 you could hear the timing chain tensioner ratchet into position after it finally got oil pressure on cold start. Not so after the cranking.Thank you, sir. I will certainly give this a try. My JLR is not a daily driver, and situation is similar to yours but not kiddo-related. My only concern is dry-cranking the engine for 10 seconds or so. But I guess that's the idea; to get the oil moving to the important bits before the rpms skyrocket.
