Installing Rooftop Tents
Bootloot
Anthony
Cary, NC
2020 Jeep Wrangler JL Rubicon, 4 dr, 4 cy.
Here’s the solution that I used. I can put it on and take it off without any help. The lift was pretty easy to make and I would share the details if you are interested.
Not only does this look like the best solution I have seen, you could probably start selling this as a solution!
JimLee
'19 JLU
Jeep Wrangler JL Installing Rooftop Tents 41188_I
Harbor freight has these gantry cranes, I have mine setup in my backyard because neither it or my Jeep fit in the garage. I'm going to add a HF winch to it. Pull Jeep in, connect winch to battery, hoist RTT (and rack, for me) drive away until next time. Warning, this thing is a bitch to pick up from HF and set up, have a friend or two.
redsyphon
North Florida
2018 JLU Rubicon
IT Project Manager
Kansascoast
Kansas
Wrangler JKU, 2drJL
If you can share those details, that would be great. I was originally thinking of a hoist on the ceiling of my garage that could be used to remove the hard top plus a roof top tent. I was then thinking about possibly having to remove the ladder to hopefully gain 6" so I can squeeze through the door.
Your solution looks like it fits the bill plus you would be able to use it to remove/install the hard top. It looks like me and another poster are interested in it so if you can share it, that would be most excellent!!!
Thank You!
Since I didn’t document this as I made it I’ll just try to explain. First I started with the receiver (pic 1)...it is 2” square tubing with a short piece of 2 1/2” od pipe welded to it. This serves as the swivel. Inserted into this is the “heights” section which is 2” od pipe. This could be all one piece or sectioned sectioned (as I did) to be able to break it down more. On the very top is another 2” square tubing that extends far enough to reach the center of your tent. My overall height is 88” and the square tubing extends 42”. On top of that is mounted two pulleys to guide the cable from my winch. I bought a Harbor Freight winch that is remote controlled for around $49 on sale and hook it up to my battery when I use it. For the lift bar I welded two pieces of angle iron together (for strength) and then cut slots in the ends (pic 3 & 4) to run straps through for lifting...this keeps things from slipping. The 5th pic is of the whole setup along with the tent stored on the garage wall.
If you were to try to use this to remove the top it would have to be a lot higher to allow the top to swivel and clear the roll bar.
Jeep Wrangler JL Installing Rooftop Tents B1CFD3FC-A382-47F2-AE36-FF0A166F737D
Jeep Wrangler JL Installing Rooftop Tents 8BC335FD-91CB-4721-931E-379AFC455AC3
Jeep Wrangler JL Installing Rooftop Tents F844A5D4-BC36-4CDA-8DCB-390D582F7438
Jeep Wrangler JL Installing Rooftop Tents 29735567-4D92-4D88-A1F2-F2E9EAAF392E
Jeep Wrangler JL Installing Rooftop Tents 3DB243FC-8A53-4E73-B43A-27D9B5EB2DE0
Jeep Wrangler JL Installing Rooftop Tents FFFA83A3-CCB8-4EC8-98C1-DA3EE7EB9BF5
Jeep Wrangler JL Installing Rooftop Tents 3B7AC5B9-CE9C-46EB-90A8-6ED5396A9B61
Jeep Wrangler JL Installing Rooftop Tents F8872D43-AA33-4A55-BAD1-DC2B7C17877B
Jeep Wrangler JL Installing Rooftop Tents CD2FFD16-EA79-499D-863D-38E92B5A9BBB
Jeep Wrangler JL Installing Rooftop Tents E8E58FB1-B3C4-4A40-BC86-FBB4DE23B016
Jeep Wrangler JL Installing Rooftop Tents C6271A54-ACB0-455D-B6C1-1A83F67C8D17
Jeep Wrangler JL Installing Rooftop Tents BA9C8BF3-C1E4-4828-84C2-6BEA583441EA
redsyphon
North Florida
2018 JLU Rubicon
IT Project Manager
Since I didn’t document this as I made it I’ll just try to explain. First I started with the receiver (pic 1)...it is 2” square tubing with a short piece of 2 1/2” od pipe welded to it. This serves as the swivel. Inserted into this is the “heights” section which is 2” od pipe. This could be all one piece or sectioned sectioned (as I did) to be able to break it down more. On the very top is another 2” square tubing that extends far enough to reach the center of your tent. My overall height from On mine that is 42”. On top of that is mounted two pulleys to guide the cable from my winch. I bought a Harbor Freight winch that is remote controlled for around $49 on sale and hook it up to my battery when I use it. For the lift bar I welded two pieces of angle iron together (for strength) and then cut slots in the ends (pic 3 & 4) to run straps through for lifting...this keeps things from slipping. The 5th pic is of the whole setup along with the tent stored on the garage wall.
Awesome!
Shamwedge
IL
2021 Sport S | 2 Door | 6 Speed | Hydro
This is awesome. What roof rack system are you using?!
Kansascoast
Kansas
Wrangler JKU, 2drJL
I made my own system...which transfers the weight from the top to the body of the Jeep by adding inside supports. The only thing that ”shows” is the eyelet on the top when the RTT is removed. This system allows the top to be removed by only removing the factory hold downs. The tent supports are permanently mounted to the tent and I can attach the tent by just using the four bolts that pass through the eyelets.
Jeep Wrangler JL Installing Rooftop Tents 33EE6E53-9A0A-4BE4-9EB6-3456BB8560E6
Jeep Wrangler JL Installing Rooftop Tents 6EAF1112-B4FE-43DA-ADAD-92EAF828FE47
Jeep Wrangler JL Installing Rooftop Tents B3ABC766-4D77-4D7C-AD4A-13B31E0B048A
Jeep Wrangler JL Installing Rooftop Tents B19F5625-FB5F-4B3F-B067-290B7D9F9DBF
Jeep Wrangler JL Installing Rooftop Tents 4E0CF472-CB72-4405-88D4-BB88D5F9CFD0
ThinkOutdoors
Sebastian
New Jersey
www.youtube.com
Jeep Wrangler JLU 2018
I'm assuming you made that bracket/support piece that sits against your hardtop yourself(in pic #1)?
Sgt Beavis
Rick and Miyako
Wrangler JL Unlimited Sport S
The Man, The Myth, The Legend. In my own mind.
I just use my Racor storage lift. It pulls my RTT more than high enough to get it up on my the Jeep or my Raptor.
Jeep Wrangler JL Installing Rooftop Tents 51093989170_a8f5fdfba8_b
nU7OuxIx
Chicago
How tall or long is the vertical? Very nice work.
I've seen that one before and it looks nice. Personally, I ended up going another route because I'm not confident in my welding and had trouble trying to source parts.
I ended up buying two deer gutting stands that stand maybe about 10' tall. I put a few 2x4's between them and raise and lower the tent onto the Jeep using this method. I don't think that it's the greatest, but then again, other than being able to pull into a garage or overhang, I'm not sure there's a best way to do this.
jim00
New England, US
JLU
Any pics for us of how that works - seems like an interesting option!
nU7OuxIx
Chicago
Hopefully this link works...
I got the idea for it here. I bought the same hunting stands. Like this person, I have an iKamper, that weighs about 160lbs. He used two 2x4's as crossbars. I did that, but started to see a pretty big deflection in the wood when raising it. I ended up screwing another 2x4 so it's really mostly a 4x4, except for about 5" at the end, where it connects to the coathanger part of the deer stand.
I also have a Yakima crossbar set from years ago. I ended up bolting the yakima crossbar to the ikamper and then insert an (maybe) 10' long piece of black pipe through the yakima crossbar. I then tied it into those 2x4's mentioned above. The reason for this is because when it's sitting on the 2x4's, it's not attached to anything, possibly causing the tent to go sliding forward or backwards.
I tried to build the following:
I followed this guy's instructions to the T, but it wasn't strong enough. When I was using my winch, I think that the winch wasn't smooth enough and caused the top 2x4's to bounce enough to where it started cracking the wood. Once it cracked, the one failed. Then the other 2x4 failed. Then my tent slid down the a-frame and by some miracle, instead of falling 8', it only fell about 4' and the black pipe got wedged in the a-frame part. There was some scratches in the tent, but overall, I was extremely lucky. This is why I ended up probably over-engineering my hunting hoist platform.
Let me know if you have any questions. Like I mentioned above, I think that a ceiling mounted hoist system is the cheapest, safest, and easiest option. I personally can't pull my Jeep into the garage with the tent on it so that method is out. I've used the hunting stand method twice and while it works, I still cringe a bit when I load/unload it.
