In between lift kit sizes
ChadPARubicon
Chad
Conshohocken, PA
2024 Jeep Wrangler Rubicon-two door gas V6
Hi,
I am considering a Clayton 1.5 inch or 2.5 inch lift for my two door Jeep Wrangler Rubicon. Ultimately I would like to run 35 inch tires on it. I know the 1.5 kit looks great with that setup and some run the 35s on the 2.5 inch kit as well. Is it possible and effective/safe to run a half inch or three quarter inch spacer with the Clayton springs to get somewhere between the two lift sizes? A spacer such as the Teraflex or other brand. Input is sought and would be appreciated! Any issues?
-Chad
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Yes, it's possible. I wouldn't though. Not because it's detrimental, but because you can run a 35" tire stock and with 1.5" lift you'd be at the "max" height I would run with a 35" tire. Why raise the center of gravity and get the abhorrent and unsightly look of a taller lift with 35" tires. Just make little or no sense to go higher than 1.5".
azwjowner
Phoenix
Have I ever mentioned how much I love your sensible posts?
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
Guys run 2” lifts on 35s all the time. It looks just fine, it’s not detrimental, your center of gravity isn’t going up a crazy amount on only half an inch. At 1.5” you’d be at the minimum height I would run with a 35” tire. Just makes little or no sense to run 1.5”
Megawatt
Sin City aka Vegas
money pits: Turbo Busa, Street Bob, 22JLUR snazz, 5.0 mustang MT
Powerplant operator
You purchase 1.5” kit and you end up with 2.5”, don’t forget.
Remember many lifts are designed to be loaded down with steel, armor, etc. so if you don’t have heavy stuff your definitely getting higher lift than what’s on the box.
rohdawg
Long Island, New York
Merchant Marine
I’ll second what @AcesandEights says and add Clayton is very specific about which kit to use to achieve what you’re trying to do. It’s all spelled out on their website and they are extremely helpful and willing to talk with you if you call them.
ChadPARubicon
Chad
Conshohocken, PA
Yep! I forgot to mention the following. The Clayton 1.5 really gives a two door around 2.25 to 2.5 ish. Some sport two doors on the Clayton 1.5 report at least that amount. I have two door Rubicon.
AdamG
Adam
SE Michigan
2019 JLSportS - SOLD; 2026 Moab 392
The Clayton 1.5 got me 3” on my 2dr SportS (soft top, plastic bumpers, no rear seat). I run 35x11.5, no rubbing when flexed.
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
Well, here’s a pic of my Metalcloak 2.5” Gamechanger and 35’s if it helps your decision any.
I got exactly 2.5” of lift in the rear and 3” up front, but the extra up front is likely compensating for the 3/4” of sag my winch added to my stock springs.
Jeep Wrangler JL In between lift kit sizes 1706061762221
autotragic
the cornbelt
'21 JLR 6MT
Supposedly the OME 2 door lift (JL2DLK) is only 1 inch for Rubicons and 2 inches for non Rubicons. My plan is to run that with 35s. I need my Jeep to fit in my garage and I want a little bit of lift and more suspension travel without riding rough.
ChadPARubicon
Chad
Conshohocken, PA
The MC 2.5 is definitely a good look with 35s. There is also a white one on here with silver wheels and that one also looks great.
Monteluis
Luis
Imperial
2024 wrangler rubicon 2door
What you mean by ome ? What brand is that
