How to reduce thrust angle JLUR
E_H_Taylor
Arizona
I have 2021 JLUR with 2" Mopar lift and 37" tires. I added front upper and lower adjustable control arms and a front adjustable track bar. Had the front control arms adjusted to increase castor to 6.0 degrees to improve the steering. When I had the alignment done I noticed the thrust angle was high (0.23 degrees) and I wanted to lower that value. Would adding an adjustable rear track bar lower the thrust angle, or would it also need adjustable rear lower control arms?
Thanks for any advice.
BDinTX
Dallas, Tx
I had a similar experience with my thrust angle at .31* after a lift. I also installed a geo correction bracket and adjustable trackbar when I put on the lift but wasn’t very careful about centering the rear axle (it poked passenger 1/3” more). Dealt with it for a while and @Roky pointed out in another thread that an off center axle will change your thrust angle because it essentially pivots on the rear UCAs & LCAs. If you don’t have either of those items to center your rear axle adding one should help. I got mine down to .07* after spending some time tweaking the TB. Then had the front alignment redone. Now it drives very nice.
Jeep&dogs
Jim
Cedar Lake
2020 JLUr
Adding a rear track bar and getting the rear end centered should get you under 10. To get it perfect you need all 4 rear control arms. The frames on these things have a +/- 10 mm tolerance. I have seen literally 100’s of these things on frame rack measuring systems and it’s sickening how far out of square some of these things are from the factory.
