How to power USB-C after replacing head unit
Bnelsonjax
Omaha
2019 Jeep Wrangler
Hi,
I replaced my head unit, so now my USB-C doesnt work. Im wanting to remove the cigarette lighter plug and put my sub volume control knob in its place. But then I need power for my phone so i want to take the USB-C plug and give it power again so it can charge a phone or whatever. How can I do that?
Jeep Wrangler JL How to power USB-C after replacing head unit 1750112556394-th
VKSheridan
Vince
Broken Arrow, OK
2020 2 Dr Rubicon JL Hardtop
If all you want is the ability to charge devices off it, I reckon you could connect it to a DC to DC buck converter that will step the supply voltage down from 12VDC to 5 VDC.
If you’re want it to interact with your new head, your head will need a USB-C compatible input receptacle. If it does, you can cut a charger cable to plug one end into the head and solder the other end to your Jeep’s USB-C harness.
Terrymo
Terry
2023 JLURXR 3.6 ET
I was thinking the step down was already present on that usb module and since he’s ditching the cig lighter, and only wants to power the usb module, just splice into those cig lighter wires for power. Beyond that it’s above my pay grade.
VKSheridan
Vince
Broken Arrow, OK
I’m pretty sure the USB outlets get their power from the head via the same harness that carries the data to the USB inputs. If they powered elsewhere, it seems unlikely they’d go just by swapping the head. That said, Jeep does some silly things so you may be right! A quick voltage probe should answer the question once energized.
Bnelsonjax
Omaha
2019 Jeep Wrangler
Hi, thanks for the reply. I just want it to charge the phone, not interract with the head unit.
Terrymo
Terry
2023 JLURXR 3.6 ET
Makes sense. The usb module at the back of the centerconsole has 12 volt power running to it and it’s stepped down at the module itself. Now you have me curious about the one on the dash.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I'd agree, there's power at the dash, but I wouldn't expect the USB-C power to die if that provided the power just from disconnection of the USB. Be interesting to hear if OP has power in the console:
Jeep Wrangler JL How to power USB-C after replacing head unit 1750175530038-f9
RatZero
Canada
2024 Willys JLU
Manufacturing @ Stellantis
I would find the original wire that connects to the now non-functional USB C outlet that the new head unit didn't use and connect that to the 12v outlet. Verify that the USB C outlet can deal with the 12v source (stepdown/up if required)
But, if I was doing it I would just build a new USB hub and power it with the 12v outlet source you're replacing with the Sub knob.
Price1961
Jonathon
Pennsylvania
2024 willys unlimited
Gregj
Greg
West Texas
I replaced all the cigarette lighter/power ports with those plugs.
Jeep Wrangler JL How to power USB-C after replacing head unit IMG_9177
Jeep Wrangler JL How to power USB-C after replacing head unit IMG_9178
Gregj
