How many rock lights?
gek
Code Monkey
First, think about the rocks below you. Pointing straight ahead isn't going to do much for what's under your tire, and won't help seeing your rear tires. Second, think about the spotter. It'll give them better visibility to place you where you need to be.
The top of the tire isn't going to help the spotter, the bottom of the tire is, which is why lights in front and behind the tires should be better for spotter visibility. Ideally they are angled slightly to cast more light on the tires contact area. As far as I can tell lights on top light up the top and inside of the tire and do not get much light on the outside and bottom of the tire where the spotter needs to see.
Wheel well lights would also be more likely to be directly visible by your spotter shining directly into their eyes hindering their ability to spot you.
As I said before, I'm not saying they can't work, just that it seems like there is a better place if the goal is visibility of rocks around your tires.
Nordekai
Kai
Virginia
2022 JLU Willys XR
Healthcare
@gek .... well shoot I should probably read things more than once. I thought y'all were talking about front end lights, not wheel well lights.
On THAT note ... I completely agree with you lol
KC HiLiTES
Rock Sponsor (Level 1)
Robert B.
Flagstaff, AZ
2020 Jeep JT, 1969 Wagoneer
Lighting Adventures Since 1970
I have two of those cyclones under my hood, for light. The infinite off road have those magnets, so easy install, but definitely not as bright
We also offer a magnetic mount for our Cyclone Rock Lights. Plus, you can add up to six additional lights to the included bus bar, allowing for a total of twelve lights—far more than anyone should ever need.
Magnet Mount Kit for Cyclone LED V2 Lights - 6 Pack
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
wcjeep
Earth
YJ with stuff. JL 2dr Sport
Recommend a few more than you think you need. Future expansion. Broken lights happen.
