How did you configure your dash?
randyhub
Randy
Calgary AB Canada
2020 Rubicon, 2017 Toyota Highlander, 2007 Toyota FJ, 2019 Suzuki DR 650
Curious what options you chose for the top right, center, and display left windows? I typically have the Eco display up which shows the range and mpg, and my Uconnect displays the temp and direction already. I have trip meter top left, Android Auto in the center, and time right side.
Thanks
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
I have a 2.0, so the main center is the engine temp. Top center is speedometer, upper left is compass, and upper right range
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Have the outdoor temp in the upper-right corner, miles to empty in upper-left, small MPH speedo at top in between those and below that, it's usually on the tire pressure screen (or voltage or oil pressure). Think the only other change is to show the numerical gear indicator over the PRND indicator.
rk911
Rich
DuPage County IL
'23 Wrangler Sport 2D, '10 Liberty, '46 Willys
Retired and loving it!
Just the outdoor temp in the upper left and the speed in fhe center.
THAW
Foster
23 JL4DrRubicon
IIRC, boost/vacuum data is possible only via the Tazer device?
Correct. The Tazer menu lives in the Audio menu, so technically the upper dash custom display is set to Audio (where it normally would show the audio input/content), and the Audio/Tazer menu is cycled to Vac/Boost.
Max Headroom
Western Slope Colorado
2021 Sting Gray Wrangler Unlimited Rubicon Diesel (JLURD) The Millennium Pidgeon
broadcast news
Thanks
UL - Compas
UC - Trip A
UR - Temp
Usually the center is on the MPG - eco graph
Current gear (it's an auto) is enabled
I usually run the center screen on the off road, extra gauges setting.
Max Headroom
broadcast news
I run a Scangauge III and can see boost, the VGT position, regen status, EGT, intercooler in/out and many other things.
zouch
Berkeley, CA
XJ, JLUWD
i also typically keep the main screen on the TPMS.
Range on the Top Left.
Compass in the Center.
Outside Air Temp on the Top Right.
i have all the other things that are interesting to me displayed on an iDash.
jludave
The Isle of Long
IT Manager
Range on top left.
Compass in center.
Outside Air Temp on top right.
DarthAWM
Mick
Odessa, TX
2021 JT Rubicon
Oilfield Dispatcher/Semi-Professional Adult Film Star
I really can't recall what I keep in the UL avg. economy I think, upper center is speed, upper right is range. and main is usually the instant economy gauge so I play mind games with myself to get good gas mileage
