How Can We Help?
Phantom01231
Richard
Houston
2020 Jeep Wrangler Unlimited Rubicon Recon
Hi Guys!
We are pleased to have the opportunity to support such a dedicated and enthusiastic forum. As an authorized Mopar Parts and Accessory retailer we are here to help answer any product questions you may have. We also welcome any part inquiries you may have no matter how big or small. I should also note we have some of the best pricing around :rock:
Please feel free to reply here with any inquiries!
Thank you,
Benny
Quick question I have. Ive been looking at HD Diff covers. I like staying with OEM parts and such. Will the HD Dana 60 diff covers work on the M220. Jeep is 2025 JLU Rubicon X.
avesalces
Paul
Virginia
Hi Benny,
I'm in a bit of a pickle here. My jeep had some aftermarket front fender flares on it that broke, so I bought a high clearance fender flare kit from MP concepts to replace the broken ones. The problem is the MP Concepts kit assumes I'm taking of OEM flares and have hardware I can reuse.That means I need all the screws that mount the turn signals and marker lights, as well as whatever other screws and washers and such that hold the flare and liner together. (The kit did, at least come with the plastic push pin connectors I need.)
Watching the install video for the fender flare install, I think i need maybe 4 t30 screws, 2 t25 screws, 2 8mm screws, and 7 lock nuts for each side, but I just can't confidently find part numbers!
My local dealership can't find me parts numbers, and neither can any of the the local auto parts stores, who refer me back to the dealership. I called jeep, and they gave me a number (and exorbitant quote) to have my jeep towed to a dealership. I just need a few silly parts to be able to put this thing back together and get on the road again!
Any help you could provide would be greatly appreciated.
etoften
Eric
Washington NC
2021 JLU Willys
Hey Benny. Any info on the rubber cover over the child safety locks? 2021 JLU. Not hurting anything not being there. But i can't unsee it every time I open the door.
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Hey Benny, stupid question, I would buy the quoted entire grille with key hole AS WELL AS 82215137AC (the hood lock kit for 20-23) but only use the lock, not the insert for grille, correct?
Hi Mike,
There are a few unknowns about this. As mentioned this is a factory order option described as Sales Code LS9 - THATCHAM SECURITY EQUIPMENT. When trying to research the factory cylinder and hardware for this option I am unable to find anything listed. I think this may be a rare export or governmental option. With that said I am not sure if the accessory lock kit will line up and work with that grille opening.
If you would like to give it a try let me know and I will send a coupon code you can use,
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Richard,
From what I recall they will not work on the 44. There is also a Super 44 dana model cover that also will not work and currently Jeep has no offerings.
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Benny,
Hi Paul,
Many of this hardware is listed poorly if at all within our dealer data. Here is what I am able to identify below by description followed by part number and photo if available.
I also attached a diagram of what we have to work with.
DRL Bracket to flare bolt - 6509795AA
Jeep Wrangler JL How Can We Help? 1761356723326-ps
Bracket to Frame Lock Nut - 6509799AA
Jeep Wrangler JL How Can We Help? 1761356849395-j4
Front Liner to Flare Bolt - 6508709AA
Jeep Wrangler JL How Can We Help? 1761356980557-em
Front flare to load beam & Turn Signal To Flare mounting - 6508693AA
Jeep Wrangler JL How Can We Help? 1761357071546-hc
Hope this helps some
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
OffroadPhoto
Lydia
Hoodsport WA
2020 JLUR White
Hi Benny,
I have a new to me 2020 JLUR that leaks like a sieve in the back glass past its hard top in a car wash. My other 2020 JLUR does not. we replaced the gasket at the bottom of the window with no success and loads of time trying to find that part number. Now that Im looking for the rubber seals for the hard top and the tub and cant find them anywhere. can you assist with seals for a 2020 hard top and tailgate? rain doesnt get in as easily, but going through a carwash is awful. floods the jack area in no time.
thanks,
Lydia
Gazelle
Eric
Seattle
JLUR 4xe ordered 11/6/20; delivered 5/13/21
Hi Benny ( @AllMoparParts.com ),
Can you help me with the Recon fender flair extensions for a Rubicon? I have the rivets already and just need the flair extensions. New tires and wheels have a bit more "poke" than I want to subject my door hinges or other drivers to. Thanks.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Benny,
thanks,
Lydia
Hi Lydia,
Here is what I come up with
Rear Glass seal
https://parts.allmoparparts.com/oem...eal-68368993ag?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
Left body to top seal
https://parts.allmoparparts.com/oem...eft-68370981ac?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
Right body to top seal
https://parts.allmoparparts.com/oem...ght-68370980ac?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
Let me know if you need anything else!
= Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
OffroadPhoto
Lydia
Hoodsport WA
2020 JLUR White
Benny, first line item, is that reference number 12 in the exploded diagram? Then I have a winner!the other two are stated to be forward of the rear... like number 8 which I dont see leaking. The second seal I was asking for is attached to the metal of the vehicle at the rear which closes against the tailgate. about as long as #12
Thanks
Lydia
kingartemis
Hagen
2021 Jeep Wrangler Sahara Unlimited
Hello Benny, I was rerouted to this thread, I have recently acquired a 21 jeep wrangler and the interior trim piece that holds some sort of wiring in place on the top part of the hatch back, below I have attached a picture to see if you can help me identify it. Thanks!!
Jeep Wrangler JL How Can We Help? IMG_C57EB49D-8519-4D39-8A11-3E1C68CA568D
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Thanks
Lydia
Hi Lydia,
Assuming we are both looking at dealer data diagrams below then Yes
Jeep Wrangler JL How Can We Help? 1761692485430-xs
#12 = 68368993AG
And the upper tailgate seal you are asking about is 68251538AE (not shown above)
Please let me know if you have any other questions.
Thank you,
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Hagen,
This can be ordered here https://parts.allmoparparts.com/oem...ate-68368994ad?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
Jeep Wrangler JL How Can We Help? 1761693019483-lu
Thank you,
- Benny
