How Can We Help?
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Thanks, VIN is 1C4PJXFNXSW563712. Appreciate any help!
Thanks, Your part number is correct. Its on a slight backorder but there is ample inventory incoming so assuming your dealer placed it on "special order" which is a higher prio than standard they should see one in about a week or two.
Please let me know if you have any other questions.
Thank you,
- Benny
wanted
Kansas
2021 jeep rubicon (pending)
Benny, can I get the current part number for the 2024 3.6 wrangler pcv valve?
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Yes Part # is 68548886AC
Thanks,
- Benny
deepseaballee
Austin
Alaska
2020 JLU
Hey Benny,
I was wondering if I could get some help with an OEM steel bumper skid plate. I have a Sport Wrangler and I bought a steel bumper off Facebook Marketplace and I’m now trying to install the skid plate. I have the two brackets that mount to the the frame, I just need the nuts and nurserts to mount the brackets, some more of the blackTorx bolts to mount the skid plate to the bumper, and the bolts to mount the skid plate to those brackets.
The steel bumper is one of the newer 2024-2025 steel bumpers that come with the 3-part winch plate if that’s important or not.
Would you happen to know the part numbers for those? Picture for reference of the spot.
Jeep Wrangler JL How Can We Help? IMG_4293
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hey Benny,
Hi Austin,
Sure things, We offer a kit here https://www.allmoparparts.com/sku/jljtskidplthw.html
Since you have some of the hardware already here are the individual items you asked about
Rivnuts
https://parts.allmoparparts.com/oem...-m10-6511076aa?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
Bolts for rivnuts
https://parts.allmoparparts.com/oem...x-head-6101848?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
The 7 bolts to the bumper are Hex bolts as per the skid plate kit however I may be able to find Torx heads if you prefer?
https://parts.allmoparparts.com/oem-parts/mopar-screw-6512587aa?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
- Benny
deepseaballee
Austin
Alaska
2020 JLU
Hi Austin,
Rivnuts
https://parts.allmoparparts.com/oem-parts/mopar-mopar-rivnut-m10-6511076aa?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
Bolts for rivnuts
https://parts.allmoparparts.com/oem-parts/mopar-mopar-bolt-hex-head-6101848?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
- Benny
Thank you, this is incredibly helpful, I actually have a few of those bolts in my bag of loose parts for the bumper.
The Torx head bolts look to be the same bolts that hold the end wings of the steel bumper on. If you can find the link to those that would be super helpful. I’ll have to source some nuts for those bolts but that will be easy enough .
This was the reference where I saw the Torx bolts
Jeep Wrangler JL How Can We Help? IMG_4298
Duc Hunter
chris
Jacksonville, Fl
2021 Jeep JLURD
Benny. I have a 21 JLURD and moved to 35” tires. I have the spare tire carrier part # 68542437AC and need the camera mount tqht goes in side of it. I ahve bought 2 off eBay, neither fit. Everyone seems to think they are all the same 2018-2024. My camera has the 2 screws that mount it to the mount taht slides into the carrier. Every camera mount I find does not accept the screw in camera??? All my searching tells me that my backup camera extension should uses clips a not screws??
Can you help me find the right
My camera
Jeep Wrangler JL How Can We Help? IMG_5014
The mount I keep being told fits a 2021 camera
Jeep Wrangler JL How Can We Help? IMG_5016
The new tire carrier
Jeep Wrangler JL How Can We Help? IMG_4935
The tire carrier part number
Jeep Wrangler JL How Can We Help? IMG_5019
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Got it, Those bolts would be https://parts.allmoparparts.com/oem-parts/mopar-screw-68355472aa?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
Thanks,
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
My camera
Hi Chris,
From Jeep that inner piece is not available as a service part.
Send me your VIN please so I can check a few things then I will recommend the part # you need for an assembly
- Benny
Duc Hunter
chris
Jacksonville, Fl
2021 Jeep JLURD
Hi Chris,
- Benny
Sent you a PM with my VIN. Thank you
Nick
Salcha, AK
2020 Wrangler Rubicon Recon
Can you ship USPS to Alaska? The website wants to charge me $145 for shipping on a wiring harness.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
Typically not, we use UPS Ground Saver as our small package economic solution but recently they stopped shipping to AK. DM me your info with email address and I will research some options.
- Benny
TakingChances
Chance
Georgia USA
2018 JL Wrangler
Hey I've tracked down coolant leak that seems to be getting a bit worse and with the cooler weather approaching im looking to get it fixed. Ive pulled one part number off of the leaking hose but there is a small hose connecting too this main radiator inlet that the leak is coming from. Main radiator inlet hose pn 68280782AD. Ive added a photo below of the hose and circled the "T" fitting that the leaking hose is connected to. I cant seem to find a part number on that hose.
Jeep Wrangler JL How Can We Help? 1764797492640-rh
Thanks!
