Hot weather
Rufus
NYC
2018 2 door JL Sport 3.6 V6
I drove across FL twice in the last few weeks. The day trips were during about 90F temps. The engine was very sluggish around 70mph. 6th gear was almost unusable. I have a 6mt on a Sport. I do run 33.25” tires.
Driving back at night the temps were in the high 70s (about a 12 degree difference). The engine felt strong and seemed like it wanted to go faster.
I noticed the oil temps were about 10 degrees higher during the daytime legs.
Is this performance typical for that temperature difference? Is this the result of some torque reduction when the engine oil gets too warm in order to reduce the risk of fire on the 6mt?
Thanks.
p.s. I had the top down so I wasn’t even running the AC. I did have the top up at night but I doubt if it makes that much of an aerodynamic difference.
JLJeepGuy513
Ivan
2018 JL Sport, 2024 Pathfinder Rock Creek
Civil Engineering Designer
Thanks.
Thats kinda typical here. When its hot and muggy, the engine runs more sluggish and when dry and cold, u get more power. The heat down here in south Florida along with 100% humidity is unbearable!!
Rufus
NYC
Thanks, I figured it was an induction efficiency effect but was just wondering if it was some sort of “feature” given the clutch heat issues. I was also a little surprised at the 12 degree temperature difference being so noticeable but the humidity also made a big difference I’m sure.
xsaltlifex
Eric
Tampa bay area
2021 black on black 6 spd 2 door
Thanks.
Top up and top down makes a 3 to 4 mpg difference on my m/t sport on the highway.
Rufus
NYC
Thank you. The next time I’m driving in those types of conditions I’ll pull over and put the top up to see if I notice the difference.
