Help with stripped bumper holes?
jmh36
Chicago
Jeep Unlimited Rubicon 2021
Finally received my JCR bumper bar for the steel bumpers on Rubicon. Went to install and one side went perfectly, as I went to the other side to finish bolting down, only 1 of the 3 bolts on the left side would go back in. I have never touched these bolts other than removing them before this. It seems as if the “bolt holes” themselves are stripped. These bolts went in perfectly to any other slot. Even removed the bumper bar altogether and they still would not go back in. They just spin in place. Any ideas? See images below, thanks in advance
Jeep Wrangler JL Help with stripped bumper holes? 2AC1A033-C8F5-491C-A4BB-EAA83C6B2C2C
Jeep Wrangler JL Help with stripped bumper holes? 26419985-CC8D-4CDB-AAED-E5CC05C8EF8C
Jeep Wrangler JL Help with stripped bumper holes? C6C2BC35-7814-4592-98FF-C3B1569E7390
MKC JL
mike
Mtns. of Va.
2022 Wrangler JLU ,2019 Cherokee Limited
I'd try using a tap & chase the threads if they won't start & thread in.
smokeythecat
2021 Willys Sport 2-door, 2019 Mini Cooper S
Did the threaded end of the bolt get damaged such that the entry point to the thread is closed off?
That is exasperating. Can you post a close-up image of the end of the bolt?
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
No panic, It’s not the bumper that is threaded, it’s just c clips under the bumper. Just get new ones. Happened to me when I switched from the mopar to the warn bar. But I managed to get the 2 problematic clips to bolt-in again.
Jeep Wrangler JL Help with stripped bumper holes? 12932488-4129-4AB3-87D4-16EA01F6F11F
jmh36
jmh36
Chicago
No panic, It’s not the bumper that is threaded, it’s just c clips under the bumper. Just get new ones. Happened to me when I switched from the mopar to the warn bar. But I managed to get the 2 problematic bolts to bolt in again.
Phew! Thank you for the help, gotta love the forum
kah.mun.rah
Merenkahre Jr.
Duat
Can you just use the ones that are on the sides that were used to hold the endcap bolts? I haven't looked inside of my bumper but by a mfg standpoint it would make sense that they use the same style of clip in the middle and on the ends.
jmh36
jmh36
Chicago
Going to check and see tomorrow, good call
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Yes same?
