titojips
- John
- Nov 24, 2021
- Los Angeles
- 2019 JLUR 2.0L Sting Gray
I had a mopar lift installed on my 4xe Rubicon before delivery. Out on the trail with sway disconnected I heard some loud noises while really flexing it. I wasn't sure if this was normal, so I hopped on here to do some research. It didn't seem like normal sounds and I came across discussions about recalled lifts, etc.
In my research I found a Mopar sheet listing the part numbers for lift components for each model. Crawled under the Jeep and my nothing was from the 4xe kit. Rear springs were from one kit, rear shocks another and same with the front. It's like someone filled a box with whatever was on the shelf and shipped it to the dealer as a 4xe lift.
I sent pics to the dealer and they ordered another lift. This past week they put the new lift on with all the correct part numbers. When I got it back it looked shorter, and the bumper cap behind the rear wheels had been removed. (Piece that commonly rubs) I'm running 37 ko'2s and had never had any rubbing.
Best I can tell the correct lift is two inches shorter in the front and about an inch in the rear than what I had. I think everyone can agree this is giving me a bit of performance anxiety. I had 9 inches between the tire and fender before and now I have 7. Maybe 7 is fine, but it's disappointing if your used to 9. Probably not as bad as going from 5 to 3 but still an issue.
So how do I regain my swagger. Do I put spacers on top of the mopar lift, if I do will I need new links or other parts? Do I kiss my 2k installed lift goodbye and start over? Do I convince myself that 7 is fine, it's not about height, more in the motion? I'd love to know if anyone has successfully installed a lift extension that still performs!
Sorry to hear that!! If it comes down to you having to cut your losses in the end. MC cloak makes a great high quality kit for 4xes
https://metalcloak.com/jeep-jl-wran...es/jeep-jl-wrangler-suspension-lift-kits.html
