fspalt
- Frank
- Oct 26, 2021
- Baltimore, MD
- 2021 JLUR
So l’ll start with saying it seems like everyone has had good luck with their ACT clutch and ACT is trying to help me work through this issue.
Took my 21 JLUR in to swap from the factory clutch to ACT pro mass clutch. No previous issues with the clutch and it looked great upon inspection when removed.
Once the job was done I asked the mechanic how do you like it and he said engagement is too close to the floor for his likening. I figured maybe it just has to break in and took it home. Then I started noticing things that suggested the clutch was dragging and not fully disengaging. Biggest test was I could have it in neutral clutch fully depressed rev the engine to 4500k and I would creep forward. Went back to the shop and talked to them to see if they disconnected the slave. They said no. Just removed as needed.
Thinking maybe I had air in the line from the factory that maybe wasn’t noticeable with the stock setup I went to the dealer and had them bleed the system. No change.
Thinking maybe the new spring of the ACT clutch maybe killed the slave / master had both of them replaced by the dealer. No change. 1500 miles now on the ACT clutch.
It’s frustrating that people have been able to do this in their driveway without issue and I’m struggling after taking it to both the dealer and the shop. I’d like to try another shop if I have to pull the trans again but I’m not sure where to turn. Original shop is trying to steer me away from the ACT clutch saying he’s never heard of them and that they look like they are a race car company. Any suggestions for a shop in the Baltimore area, especially ones that have worked on JLs would be greatly appreciated. My Jeep is my only vehicle and I’m worried the trans is going to be damaged next.
Thanks
Thanks
