HD Brakes or no
Sharkster
Pa
2020 Jeep Wrangler Saraha Unlimited
Hi guys... I'm looking to do brakes and rotors on my girlfriend's 2020 Wrangler Unlimited Sahara. How do I tell if it has heavy duty brakes on the front? Everywhere I look for front pads asks this question. I appreciate any and all help.
Thanks guys!
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Thanks guys!
The Sahara and Rubicon, both, have the Big Brake Kit on them from the factory.
You can also look up your build sheet if you wanted to go that far and it would tell you, as well.
Cutterone
NH
2025 Willys 4dr 2L Firecracker
I
I also assume my '25 Willys has the HD brakes since it has the 33's and wide D44s yeah?
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
I
Hmm... that's a good question. I don't know about the Willy's. I know if you get the XR package, you get big brakes, but the Willy's and wide axles... not sure.
You'd have to check your build sheet.
Sharkster
Pa
Thanks chevy...can I get away with cracking the bleeder to push the pistons back so I don't mess up the abs? I don't need a trip to the dealer
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
You won't mess up the ABS pushing the pistons back. I wouldn't crack the bleeders without pressure pushing fluid out. You'll just introduce air.
You can service the calipers by just pushing the piston back like normal.
Sharkster
Pa
You're a lifesaver chevy! Many thanks!
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
You'll want to bleed the brakes though.
Aonarch
Mike Hawk
North GA / MT
You don’t need to bleed brakes for changing pads.
Just open the fluid reservoir and push the pistons back. Change pads. Put cap back on.
If they are doing pads and rotors you should though.
Brake fluid is hygroscopic and should be changed every 3 years or so.
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
You’re talking about flushing then. Sure, that makes sense. You’ll need a scan tool capable of running the ABS pump for the procedure. Flush or bleed.
If he’s just swapping out pads, this isn’t a necessary or required step.
Aonarch
Mike Hawk
North GA / MT
A simple bleed will do good enough of a job.
zouch
Berkeley, CA
XJ, JLUWD
Willys' came with what was advertised as a Big Brake Kit (at least sometimes), even when they had the Narrow 'Euro' axles.
my '21 did.
Scooter2
Socal/ Northern Colorado
2018 JL Sport / 2022 F250 / 2023 Bronco Wildtrak
I hesitate to ask.. when flushing the brake fluid and ABS, I assume I also need to flush the cluch slave cylinder?
