Harkin Hoist Help
shaneR
Shane
Seattle
Jeep Wrangler Sahara JL & an Audi TT
Harkin Hoist help!
Looking for help with my Harkin Hoist. I got it installed but I can’t find an angle that gets it to release. I can lift up but not back down. To release I need to climb up and manually disengage the locking part. I’ll see if I post a picture.
Jeep Wrangler JL Harkin Hoist Help 2DFBCF76-BB1C-4850-9F5C-D1C0025BF805
Jeep Wrangler JL Harkin Hoist Help 3E5FA5F2-35DA-4B70-A340-9B98D9464011
Dudley Dawson
Northern Virginia
2026 MOAB 392
In my experience, if there isn’t any load (e.g. hardtop) on the hoist, it won’t release and lower very easily by itself. You have to pull on the ropes while releasing the locking mechanism at the same time. Unlock by aligning it in same direction as the rigging, at about 45 degree angle. Looking at your set-up, you may need someone to pull on the ropes while you release it?
HealthRebel
Jerry
Colleyville, TX
2020 JLRU Ocean Blue
I agree with the post above...Try attaching something to the hoist (not your hard top!)... at least 30-40 lbs to place tension on it to check for proper function.
shaneR
shaneR
Shane
Seattle
Thanks. I did have about 30 pounds tied to it before I took the picture. Not the weight of the jeep roof but enough to give it some tension.
Dudley Dawson
Northern Virginia
2026 MOAB 392
One other thought. I can’t tell for sure from the pic, but is the main rigging running to the side (and in between) the two lift points on the right side? If so, it may be binding at the center pulleys on the riser.
shaneR
shaneR
Shane
Seattle
Picture with a cinder block hanging from it for tension. It seems to move freely through the center pulleys so think the problem must be on the block and tackle side.
Jeep Wrangler JL Harkin Hoist Help 3275873D-9B3E-4E67-8B8F-C3C0CC34380B
Jeep Wrangler JL Harkin Hoist Help ADCC1431-9B46-4D3C-8F9F-0F93A58E367F
