Hard Top Hoist DIY - Harken Hoist
slamr
Upstate NY
2019 JLU MOAB, Harley SE Street Glide
Seanst34
Sean
Waxhaw, NC
3018 Jeep JLUR 2.0 L 4 Cylinder Turbo on 37s with 2” Mopar Lift, Inginity QX60, and BMW R Nine T Scrambler
To the original creator of this thread great post and vid. However I started to go this route to creare a “hoist” for my JKUR hardtop and realized I was over thinking it. A couple of two by fours, four lag bolts, and four ratchet straps and your good to go. The only difference being you have to ratchet all four corners individually. Super easy and I think I spent $30. I’m now using the same set up for my JLUR
shacdaddy
Miami, FL
www.youtube.com
2018 JLUR Sting-Gray
I haven’t tried that but i don’t see why you can’t do that.
Hmm, I asked the same question on the product page on Quadratec and they said the window has to be open.
Goheels050917
Dustin
Raleigh - Durham, NC
2018 Jeep Wrangler JLU (SOLD - March 2021)
SD-WAN Engineer - Technical Author
Wow...You know I was looking at this same exact thing on amazon before seeing this thread and was up in the air. Now that I've read your post, I will be $145 dollars shorter in my wallet .
Thanks alot!
Patinito
Patinito
Michael
Miami, Florida
2018 MOAB "Saharacon"
SysAdmin
the back window will not close all the way flush but I'm sure it can be folded down. The straps are thin. I have not tried it though.
shacdaddy
Miami, FL
www.youtube.com
Yeah I've looked at videos/photos of the straps on the rear window and they look thin enough for it to fold.
Maybe if you get bored today, you can try it out for me :D
Patinito
Patinito
Michael
Miami, Florida
SysAdmin
Let me see if I can test it tonight.
rockadile
PA
2019 Mojito! JLUR
I did the same thing on my old TJ with one exception...I only used 2 ratcheting tie downs running under the roof from the back to front. Worked like a charm.
slamr
Upstate NY
You may be able to use this lift but modify the pick up points using these: http://www.topsyproducts.com/products/hinge_hook_hoist_bracket
Run the long nylon webbing across the front for the two front pick up points and use the hooks (with window closed) for the rear. Would need to dial in the lines so they pick up equally. No pressure on window seal also.
Bestop
