Hardtop weight
Malve
San Diego
2018 Wrangler JLU, 2012 QX56
CEO
With all the specs available, I can't find the weight of the hardtop. Ideally I'd like to know the weight of the JLU color matched hard top.
Thanks in advance.
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
I saw a post somewhere here that mentioned the JK hardtop is 100 lbs, and Jeep says the new hardtop is 20% lighter, so that would make it 80 lbs. But this is all hearsay at this time.
Malve
Malve
San Diego
CEO
I read that the Freedom panels were lighter but I'm not sure about the main hard top.
FatBoy01
NY
2014 Wrangler Sahara; 2001 Harley FatBoy; 2018 Wrangler Rubicon JL (Ordered)
Retired @ 55
While this video pertains to a JKU, it will give you an idea how much the JLU hardtop weighs. JLU panels are lighter in weight (supposedly 20% lighter) then the JKU roof panels but again this video will give you a ball park idea. For sure, the JLU complete hard top, weighs 140 lbs. +-.
Malve
Malve
San Diego
CEO
Someone out there must know the actual weight.
FatBoy01
NY
Retired @ 55
Yup, all we need is a guy/gal with a 2018 JLU, a hardtop hoist, a Big Game scale and 15 minutes! ;)
johnnytaco
Dallas, TX
2004 TJ
If it would ever stop raining here, I would take my hard top off and weigh it. I wonder if I stepped on my scale with the hard top if it would explode.
I'm putting the over/under on 80 lbs.
jt
yeoman18
Philadelphia, PA
On Order JLU Sahara GCM
Also, on a similar theme, can someone measure how far from the back of the hard top (with rear window open) is the Center of Gravity? While waiting for for my JLU to arrive I want to build a hoist and shelf and knowing the CG would help. Thanks in advance!
FatBoy01
NY
Retired @ 55
Do painted tops weigh more?
All Wrangler hardtops are painted when they are manufactured. They are either painted black in color or painted to match body color.
For color paint code in regard to your body color matched hardtop, see white sticker on your Wrangler.
Black Wrangler Hardtop = Mopar part # 68060405AA
FatBoy01
NY
Retired @ 55
I weighed my unlimited hard top, 100 lbs. unpainted, not including freedom tops.
Front doors weigh 50 lbs each, back doors are 40 I think but i forgot to record the back door numbers on paper.
Below is what you would use for touching up a black Wrangler hardtop.
Jeep Wrangler JL Hardtop weight hardtop-paint
FreedomRider
Tony
Las Vegas
None
Forgot to put the numbers on pap....You sir, will sit in the corner for 15 minutes (without the hard top on your head--I mean, it's not like to forgot to air up after a day on the trail.)
WXman
Central Kentucky
All I know is that the Freedom Panels are WAYYYY lighter than the old JK style ones. Much easier to handle.
