Halogen fog to LED question
Mjv04tj
Pa
2021 JL Unlimited Rubicon
Upgrading my plastic rubicon bumper with halogens to a factor steel bumper that has LEDs. Will the led connectors be plug and play from halogen connectors or will I need an adapter? Thanks
-lenny-
Boyd
Alberta
JLUR EcoDiesel
It is plug and play, but unless you flash for LED lights, the new to you lights will promptly burn out. I did same swap as you are looking at. Did not flash, lights lasted long enough to function test and then failed. Had to replace with aftermarket.
Mjv04tj
Pa
So I would need a mini taser…do you have any clue if I flash for LEDs but still have halogen headlights will that be an issue?
Graphite JL
Romeo, MI
2018 Sahara Unlimited
I used JLScan to switch my settings to LED when I swapped, the lights plugged right in, but going from a plastic bumper to a steel bumper, you'll different fog light mounts.
