WranglerMan
- Will
- May 8, 2018
- Katy Texas
- 2018 Wrangler JLU Sahara
- Occupation
- Gas Pipeliner
- Vehicle Showcase
- 1
Any need to disconnect the battery for this step???I meant to attach this to, sorry
Nope.Any need to disconnect the battery for this step???
Ok so hook the negative up first then make the positive connection … assuming no disconnect of the batteryI meant to attach this to, sorry
I typically add/connect the fuse then connect the ground. Use the factory ground in the passenger side fender under the hood.Ok so hook the negative up first then make the positive connection … assuming no disconnect of the battery
Perfect!!I typically add/connect the fuse then connect the ground.
No need to disconnect the battery.
