Halo led wiring
BarbieJeep
Susan
Fort Worth
Jeep JLU
I’m a complete newbie with electrical work. And my last wrangler was a YJ. My 2023 JLU is obviously very different. I just installed LED halos to replace my halogen headlights. The only thing I’m having trouble with is where and how to connect the wiring for RGB halo portion. The instructions I received from the headlight manufacturer are very basic and unclear, and I’ve been unable to find a video that fully explains how to connect them.
the image is the only instructions I’ve received. As a newbie, I’d really appreciate some help on how to do this. TIA
Jeep Wrangler JL Halo led wiring image
Grayhound
Michigan
Jlurd
It looks like this is designed to be wired into your current drl. What I had to do to get my halos working correctly was to wire in to my fender wires for drl. I used the wire harness from my Quake fender chop kit and wire the halo to both the day time and nighttime wire for drl. I used resistors so as not to back feed electric on the circuit not in use.
Everything worked until I turned on my turn signal and my halo went out. So I learned that having the halo tied to one sides drl causes all drl to go out when you turn on that turn signal.
I then realized I had to do this to both sides to get it working the way I wanted. So I dig into the left side and did the same thing.
Looks like you’re off to a head start as your kit comes with a wire for both sides. Mine was designed to plug into the fuse box, but that didn’t give me function of the drl on/off button in the radio. I’ve also recently learned the drl shuts off with the parking brake.
In the end I’m happy I did it but it was a bit more work than I thought.
