Half Door question about locks
Mdslawn
Michael
Clinton ms
2019 Jeep wrangler rubicon unlimited
I’m looking at a set of half doors for my Jeep my full doors have proximity locks now and so does the half doors that I’m looking at. If I install these half doors on my Jeep and plug them in will my key fob work and also the proximity locks work? I know the key lock cylinder would not unless I got it rekeyed or swapped .
rjpjeep
Robert
TN
2021 JLRU
Are they MOPAR? If so, yes the locks should work. The module that is programed to your FOB in under the dash.
Mdslawn
Michael
Clinton ms
Yes they are mopar factory doors. Is it possible to get the actual key lock hole swapped or rekeyed so my keys operate everything on the jeep
YippieKiYayMrFalcon
Rob
Atlanta
2021 JLU 80th Anniversary
Swapping out the lock cylinders is really easy. I did it on the half doors I bought. They send you enough pins to cover all combinations. you just need a bit of trial and error with your key to get the right combo.
Part: https://parts.allmoparparts.com/oem-parts/mopar-door-lock-assembly-cylinder-68384449ab
Video showing the process (not on a Jeep). Took me about 40 minutes. Once you know the sequence for the first, the second is easy.
