From ChatGPT, but it doesn't seem to list things like turn assist, delaying Homelink timeouts, etc.
Vehicle Settings (persistent changes)
• Tire size calibration
• Axle gear ratio calibration
• Transfer case LOW ratio setting
• TPMS enable/disable
• TPMS pressure threshold adjustment
• One-touch lane change enable/disable
• Daytime running lights region change
• DRL location selection
• DRL dropout enable/disable
• Fog lights enable/disable
• Fog light dropout disable
• LED headlamp configuration
• LED fog lamp configuration
• LED tail lamp configuration
• LED front turn signal configuration
• Factory auto high beam enable
• Trailer tow setting enable
• Backup camera enable/disable
• Cargo camera input enable (8.4 Uconnect)
• CD input enable
• TravelLink enable
• XM traffic and weather enable
• Aux button programming enable
• Blind spot monitoring enable (if hardware present)
• Dual zone HVAC enable
• HomeLink enable
• Proximity entry enable
• 115V bed outlet enable (Gladiator)
• Front axle disconnect setting
• Electronic sway bar disable
• Electric power steering pump disable (for swaps)
• Seat belt chime disable
• Cluster splash screen change (Sport / Sahara / Rubicon)
• Full return to stock “Unmarry” function
• Read diagnostic trouble codes
• Clear diagnostic trouble codes
Live Functions (device must remain plugged in)
• Light Show activation (multiple preset and custom patterns)
• Line Lock
• Rock Crawl mode (4 wheel brake control)
• Auto Start Stop memory (remembers last setting)
• Traction control memory
• On demand sway bar disconnect (Rubicon)
• Winch mode
• Cooldown mode
• Clear codes on the fly
As shown above the Taser will let you control so many things.Why what is the reason so many people use the taser or other after market devices on their jeeps ?
only ask as a new jeep owner. What are the benefits? Aside from engine-shut off at stops by
pass mod
just curious
thanks
The last bullet point is a secret…this list was just a teaser. You have to watch the videos with Tech Tim if you really want to know. Watch until the very end for the post credit scenes.As shown above the Taser will let you control so many things.
The most common things we see the Taser used for are:
- Start/Stop disable
- Tire size setting after adding bigger tires
- Adjust tire pressure alert level for running lower pressure without warning alerts
- LED headlamp setting when swapping from halogen to LED headlights
- To read Diagnostic Troubleshoot codes and reset them
