Getting codes without going to the dealer
eugene
Gene
JLUR Ocean Blue
Hey everyone,
I really don’t want to go back to the dealer for the 900th time. Does anyone know how I can get a list of codes to tell me what is wrong with my Jeep?
I went to autozone and o Reilly’s and they couldn’t help me.
When I’m in RUN the CEL is on. Tbis means I have a soft engine code, am I right?
The other codes I want are electrical codes.
Thanks
Love my Jeep but hate how I’m having issues.
ECHO
Craig
Pennsylvania
2-Door JL Rubicon - Black
Retired Air Force - Currently in my Dream Job
Are you in RUN with the engine started?
Kidder212
Tom
Tennessee
2018 JLUR 2.0L turbo
If you are in run the CEL will be on. If the Jeep is running with no CEL then you have no codes.
eugene
eugene
Gene
JLUR Ocean Blue
Autozone didn’t run their code scanner on it?
Autozone and o reliey both tried and got nothing. I had autozone do it 3 months ago, I went to the dealer and they showed me a sheet of electronic codes they could pick up
four low
central New York
2018 JL
He did say " when in Run the CEL is on ". So, yes there are codes. I see a Code Reader that might help, called "Blue Driver", Wal-Mart, Advance Auto, $99 or so. Advertised as equalling dealer for Code information, check it out.
eugene
eugene
Gene
JLUR Ocean Blue
The Jeep was not running but the ignition was on RUN. Why would the CEL stay on when all the other lights that flash and disappear when I engage RUN Besides CEL.
Only reason I’m worried and want to see is b/c dealer put 6.5 qts of 5W-30 into my wrangler.
Only realized this because my oil pressure monitor on off-road pages was going crazy.
ECHO
Craig
Pennsylvania
Nothing to worry about unless the CEL is on when the motor is running .. as far as the oil , I would get that to the correct level
eugene
eugene
Gene
JLUR Ocean Blue
Kidder212
Tom
Tennessee
The radio is a known problem with the JL has nothing to do with over fill of oil. The radio won’t pop a CEL. If you have a CEL light on it will only be on while the engine is running for a code to be there. Other codes will appear in memory to help a tech determine problems. The CEL mostly deals with engine, transmission, and emissions quality problems.
Tumbleweed
Anthem AZ
18' JLU Auto 3.6L
In the JK you could get the codes anytime by turning the key three times from off to run within 5 seconds and it would display any CEL codes on the evic display. I wonder if JLs have a similar sequence
multicam
Tanner
near Kansas City
2018 4Runner, 2019 JLR
YJ’s had the same thing, except the check engine light would blink at you and you had to watch it and count the numbers. It took a while on my YJ :CWL:
Somehow I doubt the JL has a similar feature. It’d be nice though!
