Fuse Box Question
lookitsadam
Tampa, Florida
2018 JLU Sport
In the fuse box there are some spots labeled as "Spare *if equipped". What exactly does this mean? All of the spaces on mine labeled as a spare are blank fuse slots. Does this mean I could use the slot to connect something else to? Or is this where a spare fuse would be located if I had to use it to replace another blown fuse?
For reference - was thinking of tapping in to a spare fuse (or another fuse connected to the ACC), instead of the Aux switches in order to wire up DRL halos in after market fog lights that would always be on when the ignition is on.
DToxic
Blake
Bay Area, CA
2018 JL Rubicon
Good question that I’m curious about too. I’m looking to tap a hardwire dashcam dude kit into the fuse box.
Did you ever figure it out?
Rahneld
Ronald
Boston
JL Wrangler
Great question, don't know: color commentary.
At least in the case of those owners equipped with the cargo area 12V plug (those with subwoofers back there I think) there are two mutually exclusive slots for its fuse. One, as from the factory, makes that plug energized all the time, JL on or off: unlike the one in the dash. Move the fuse and the cargo area 12V plug behaves like the one in the dash. Trash the fuse, the plug never works. Put a fuse in each......just don't (probably behave like factory.)
Can't say that many situations like this do or don't exist with other electric things JL.
TrivialDig
Walter
Round lake Il
2020 JLUS
Ill be tinkering with this setup shortly - I can respond back when I have an answer
