Fuse box issue help please
Black JL
Ashland, Ky
Wrangler JL Sport
Locksmith
This morning I installed mopars trailer light harness. Took roughly 3 hours to install. After completing the install I have no power to the 4 pin or 7 pin connectors checked fuse box and I didn’t have any micro 2 blade fuses in the trailer spots. After picking up some micro fuses I learned the fuse box doesn’t have the connector that a fuse clips to. How do I get power if the fuse box doesn’t have the connectors.
cb4017
Cliff
Northern Nevada
2025 Gladiator Mojave
I installed the same harness last week and it's been working fine. You got me curious so I just went out and checked my fuse box. I also have no fuse connectors for those fuses (F36 and F37?)
I would check the in-line fuse on the power line you bolted to the fuse box. If that is good I would suspect you don't have one of the pins fully inserted on the power plug behind the right taillight or at the hitch plug or possibly in the wrong hole at the plug.
Took me a lot longer than three hours. I had a heck of a time getting that wire strung through the firewall.
Good Luck!
Black JL
Black JL
Ashland, Ky
Wrangler JL Sport
Locksmith
Thanks Cliff I will recheck my work and let you know. Thank you, for the help.
Black JL
Black JL
Ashland, Ky
Wrangler JL Sport
Locksmith
Update after getting off work I began looking closer at my work during the install. Everything was wired correctly. During further inspection I came across the slot for the in line fuse. However, my kit didn’t come with the fuse. After a little research I installed a 30 amp in the in line slot and all is well. Thanks again cliff.
four low
central New York
2018 JL
Good Luck!
When I did mine, Flat Four only, I heated an ice pick and pushed it through the plastic plug on the driver side, went through like butter. Then ran a fish wire through that hole, very quick and easy. Sealed with a little strip caulk when all done
cb4017
Cliff
Northern Nevada
You're welcome. Glad you got it figured out.
Rahneld
Ronald
Boston
JL Wrangler
Similar story...but one, if I'm to understand correctly, available to only automatic transmission owners(???)
