Fuel Fill-Up
kevinsmith812
Cincinnati
My Wrangler is such a pain to fill up with gas. The nozzle kicks off all the time. This happens at multiple gas stations. Even if I just hold the handle and half squeeze I only get about a gallon at a time before it kicks off.
anyone else experience this?
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
I did on my JK when it was new. Dealer found a factory worker had left a crumpled up piece of paper in the filler tube. That has been my only dealer visit on this Jeep. Hope my JL is this good...
geem03
Gary
New Brunswick Canada
2019 Jeep Wrangler Sport
RN/ Firefighter
Once in a while it happens but if I pull the nozzle out a bit or squeeze the nozzle at about 75 %and it goes away.... or angle the filler differently by rotating it a bit left or right..... but it hasn't happened for a while now....
I find it does it more in real cold weather....
Rufus
NYC
2018 2 door JL Sport 3.6 V6
There are other threads here on this and also the tank not filling to capacity. Some owners have had a part replaced, something to do with the system that manages vapor I believe. Your case sounds egregious, so I would definitely take it in and give Jeep Cares a heads up.
ArizonaJLUR
Arizona
'19 JLUR
Never happened with the Jeep, but my wife's Durango has this capless flap thing for the fuel tank and nearly every pump hates it. What I do is just rotate the handle 90-180 degrees and it won't prematurely shut down the pump
DaltonGang
Doesn't Play Well With Others
I've had the same problem, but it is usually a pump or two, that regularly is too sensitive, or pumps gas out very fast, causing the pump shutoff to be tripped.
HamiltonGuy
Dino
Guelph
JLSU
I had that problem until I figured out that if I turned the pump handle to a certain angle, the flow of gas will run without interuption.
geem03
Gary
RN/ Firefighter
It must be how the filter tube is angled or something.... causing enough back pressure or fuel turbulence at the tip to be setting it off..JMO... no data to back that up...;)
LouisCameron
Louis
Boston, MA
2020 JLU Sahara
Wife has this issue with her 2018 Jeep GC. We have to rotate the pump 180 degrees, works every time. The only thing that sucks is we live in a town that is Full Service only so the attendants usually don't realize it.
Mad Hatter
SW PA
2018 JLUR, 2011 MDX Advance
Is your problem repeating at the same pump at the same station, or multiple pumps at multiple stations? The shutoff is often a nozzle issue. One BP station near me was particularly bad on this. I figured it was a specific mechanic who adjusted the station's shutoffs for maximum sensitivity.
cosine
NY
2019 Wrangler Sport jl
Gone Postal
once in a blue moon that i will have this issue and thats mostly due to the fast flowing of the gas going into the tank. so i hold the handle at 75%. i fill up at the same station so no issue there.
