Front Trail Cam vs. Dash Cam
JourneyGirl
Christie
Leesburg, VA
2024 Jeep Wrangler 4xe Rubicon X - White
Marketing/Business Consultant, Graphic Design Artist
Hi all,
I have on order a 2024 4xe Rubi X, It comes with a trail cam in the front grille, but not entirely sure what all you see with that? (Yes, I'm a noob) .... Do I need or want to install a dash cam in addition to? and if YES, recommendations for said dash cam.
Thanks all.
Deleted User 38384
Trail cam is just what it sounds like, let's you see over that big obnoxious hood of yours. So when you're coming up on some crazy rocks you need to roll over, you'll have a better view than trying to figure out where your positioned looking past that massive hood.
I'm not keen on dash cams, but ideally something with the fair amount of storage space would be and a high quality camera would be preferred. I think @Casey250 has a video about his setup. See if I can't find the video for you...
Deleted User 38384
Jeep Wrangler JL Front Trail Cam vs. Dash Cam Screenshot_20230921-175653
For some reason or another, the 64 GB one is the cheapest. Which is really dumb because you can get a 512 GB microSD card with 180/130mbs read/write for $35 on Amazon.
Jeep Wrangler JL Front Trail Cam vs. Dash Cam Screenshot_20230921-180223
Wonder if you can save even more money by buying one without an SD card?? ?
Chocolate Thunder
Jeremy
Trail cam is for wheeling. You see the area right in front of your vehicle normally obstructed by the hood. Also great for pulling up really close when parking. It doesn’t record.
A dash cam has a higher and wider field of view. It basically sees most of what you see straight ahead when driving. It records video and sometimes sound which could be useful for accidents or interactions with the police.
Casey250
Casey
Victoria
www.youtube.com
2008 JKUR | 2020 JLUR-D | 2022 Demonator
Video Creator
That dashcam has been awesome. I really like it.
JourneyGirl
JourneyGirl
Christie
Leesburg, VA
Ty so much! Where do you have it mounted? I know zero about dash cams and not much more about jeeps… but I’m trying to learn as much as I can while uaw continues to delay my dream lol
73TAWM
Troy
Missouri
21 JLU RUBICON 2.0T 3"LIFT 37's
Lumber Sales
I looked at these and I'm confused why the higher memory card systems are cheaper. That's usually the other way around.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Me too! I only wish there was a better way to mount the rear camera further aft and still keep it simple to remove hardtop and not camera. I mounted it on the speaker bar and it's okay.
Upnarms
AZ
2019 JLUR, 2003 TJ X
I have a vantru n4 and a rove can't remember which but it's 4k. R2? Anyway, my advice is go 4k for sure, get one with a capacitor that records if the power is suddenly cut off, and one that does wifi or Bluetooth so you can change settings and download videos to your phone easily
UniqueUserName
Chuck
Bailey, Colorado, USA
1994 Wrangler YJ, 2022 JLUR-XR
I have/use both. The trail cam is to see where you're going below the line of sight over your hood. It's great for tire placement over obstacles and edges, cresting hills, etc.
The dash cam is for recording, which the Jeep trail cam does not do. We use the dash cam to capture Jeep trail rides, but more importantly to capture events on the road. We were involved in a pretty wild accident in July and the dashcam proved invaluable. I've since installed one in my other vehicle and plan to put one in all future vehicles we own.
We run a VIOFO A129 Pro Duo 4K in our Jeep and it has delivered consistently great performance. The memory card you use is also important. You want a high capacity card that's designed for security video recording (because it's constantly being recorded to and overwritten). I use a SanDisk 256GB High Endurance Video microSDXC Card.
JourneyGirl
JourneyGirl
Christie
Leesburg, VA
Thank you so much! I will check out that particular camera and some of the others mentioned! If this strike lasts much longer I'm gonna run out of things to research to keep me occupied!!! :)
Canucklesammich
2022 JLR
I'd also advise researching on YouTube; that way you can get a good idea how images look, how easy/difficult they are, etc.
Jeepiner
Jeepineer
Toledo, OH
2022 JLURD
Mechanical Engineer
I have the Blackvue 900X-2CH that others have posted. I have my front dash cam mounted to the neck of my rearview mirror, via two 4" ball bungees.
Pics:
Jeep Wrangler JL Front Trail Cam vs. Dash Cam 1a
Surprisingly it holds extremely well. Unfortunately, no company makes a proper Blackvue dashcam mount for the Jeep JL. The 3M adhesive that comes with the cams do not stay put. And I refuse to ever use a suction cup mount.
My opinion:
Get both the trail cam and dash cam if possible. Dash cams are mandatory, and the trail cam -- aside from being cool, is very useful.
Casey250
Casey
Victoria
www.youtube.com
Video Creator
Pics:
My opinion:
Use a 3m command strip cut to size. Mine hasn't fallen off even baking in extreme summer heat.
