Front bumper hoop mod
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
After the front bumper is off and the the bare frame horns are sticking out I centered the hoop and marked the new holes to drill and tap with 5/16 inch fine thread bolts into the top of the frame. You could probably use a large self tapping screw but the frame is thick enough to tap. I have a light bar on it now. (Road to crisp point light House Michigan upper peninsula during the fall JEEP CREEP)
Different subject for a moment - how do you like your hood deflector?
Tangokilo
Tom
Southwest Michigan
1972 Oldsmobile 442, 2001 4runner, 2010 Honda Accord V6 Coupe, 2011 VW Golf, 1969 Triump T100 MC and 2018 JLU Sport S
The AVS deflector fits really well and protects the front edge. I don't think it really keeps much of the windshield but the bugs come off easy from the deflector itself.
Big_Mike_NJ
NJ
2021 Jeep Unlimited Willys
I came across this thread and tried to figure out how its done. Im not mechanically inclined at all. Is there any better explanation to do this? it will complete my bumper
Htfan
Orange County, CA
There are two different options discussed in this thread:
1) Rugged Ridge hoop using spacers (previous posts above)
2) Westin hoop for the JK with a slightly modified mounting bracket to fit JL (my choice in thread link below)
https://www.jlwranglerforums.com/fo...-on-plastic-rubicon-bumper.42960/post-1388356
Both are good solutions. There are details included on each method. Once you review, let us know what questions you have.
Big_Mike_NJ
NJ
this is the style. This seems to be the spacers version. I think the modified bracket that the gladiator has with that specific hoop sticks out more right? in terms of outward part of the top part of the hoop, it seems like it bends outward more. I like the look here with the bar closer to the grill. Where exactly does that spacer go? All you need is the spacer and to take off the back bumper skin piece and drill holes on the frame and it will avoid bumper trimming? I just dont know where the spacer goes or where on the frame the holes need to be. I want to show/explain this for an auto body to do
Htfan
Orange County, CA
I think the solution I chose without spacers does "bend outward" more, but only slightly.
Jeep Wrangler JL Front bumper hoop mod 20230701_121826_resized
Hopefully, one of the other guys who used Rugged Ridge with spacers can share more details with you.
Big_Mike_NJ
NJ
So with the bracket option you used, i can’t use the rugged ridge bar he used? Only the bar you have?
Htfan
Orange County, CA
The Westin bar I installed came with the brackets to mount and are not compatible with the rugged ridge.
Big_Mike_NJ
NJ
damn I was going to go your route but realized it has the light mounting brackets. I just want it as a bull bar not for lights. Will have to figure out the spacer route.
Big_Mike_NJ
NJ
A half inch thick spacer is all it took. I did not need to trim the bumper or grill shell. I did trim the ends off of the panel that attaches to the back top of the bumper. And slotted the lower two bolt holes in the lower plastic skid plate cover.
Hello sir, is there any way to go more in depth about doing this mod? I did read what you posted, but still hard for me to understand. I have been watching videos of taking the bumper off, but not sure where this spacer goes and where to drill etc. I am trying to collect information and pictures to have my auto body do this mod.
Tangokilo
Tom
Southwest Michigan
This wood spacer goes between the front of the frame (the frame ends with a flat plate with the four mounting holes that match my wood spacer) and the whole bumper assembly.
Big_Mike_NJ
NJ
Thanks for the response. I am using a picture from the thread. Is this where that spacer goes?
Jeep Wrangler JL Front bumper hoop mod IMG_1244
Tangokilo
Tom
Southwest Michigan
Yes you got it!
