usmcss
Great info and thank you! But if 1 is one piece on the driverside, then it is still hooked to the wheel and also in the differential, so why doesn't the Driver side (1) make the Drive Shaft move? I would think that the Drive Shaft would need to be disconnected in the Differential. Or disconnected on the passenger side like it is but also on the driver side? What am I missing?The driver side is not disconnected, only the passenger side. The front differential is the reason why the ring/pinion gears and front driveshaft don’t rotate. The internal diff gears are spinning instead of the ring/pinion which is the reason the front driveshaft doesn’t spin in 2H. The internal diff gears do rotate the inner half of the passenger axle but it is disconnected from the outer half of passenger axle because the collar shown in the video is offset and not locking the passenger axle halves together. On the TJ and JK everything rotates because it does not have a FAD. The YJ was last wrangler to use FAD.
So why did Jeep return to FAD? Maybe to increase mpg slightly. It puts less wear and tear on the ring/pinion and front drive shaft and their associated bearings and seals. Puts more wear and tear on internal diff gears.
Attached is an illustration on YJ front axle. JL works same way but uses an electric motor instead of vacuum to move the collar. You can see parts 2 & 3 makes up the passenger axle. The collar locks these two parts together. Part 1 is the driver side axle which is one piece.
You could essentially add a FAD to your JK by installing locking front hubs. In theory you would only need one side unlocked to replicate Jeeps FAD design.
This system is used in RAM trucks.
