It was tough the first time I tried it, but got easier after that. You have to fold up the wiper and rock it back and forth and side to side while pulling firmly at the base of the wiper. Putting a little rotational force on it helps, as well. When putting them back on, no need to push them all the way on, just get them lined up and use the hex nuts do the work of seating the wipers. Good luck!
Yes.Anybody experience issues with the wiper not coming off easily after removal of the bolt? I removed both bolts but wiper arm seems stuck and won’t remove easily.
Can the windshield be lowered with a Power Top?
Has this been confirmed? I have the power top, but I can't seem to drop the windshield.It should be able to, the windshield frame remains intact now.
Thank You! These are excellent step-by-step instructions. However, they don't work for me. I don't know if my issue is only related to people who have the JLU Rubicon Recon or not. Here is my issue. I would appreciate if anyone could help [Thanks in advance].JL WRANGLER FOLDING WINDSHIELD
Tools Needed
- Torx #T40 Bit
- 15mm socket
- Ratchet
FOLDING AND RAISING WINDSHIELD
1. Lower your soft top or remove the hard top.
2. Remove (using your hands) the protective caps over the windshield wiper hex bolts shown in the photo below.
3. Use a 15mm socket to remove the two hex bolts underneath the caps shown in the photo above and remove the windshield wipers.
4. Lower both sun visors.
5. Use a #40 Torx bit to remove the four Torx screws located along the interior of the windshield shown in the photo below (remove screws from the same locations on the driver's side).
NOTE: Remember to store all the mounting bolts in their original threaded holes and tighten so they are not lost.
6. Lower the windshield until it contacts the foot-man loop bumpers (if equipped) on the hood shown in the photo below.
NOTE: If desired, the entire windshield can be removed by simply removing two more bolts located at the hinge at the base of the windshield (bolt location shown in photo below)
7. Secure the windshield by passing a cinch strap through the footman loops on both sides of the hood and on the windshield frame (in the areas indicated by arrows below). Tighten the strap to secure the windshield.
To raise and reinstall the windshield, reverse the steps above.
VIDEO OVERVIEW
This video we put together from the JL Wrangler LA Auto Show debut provides an overview look at the process.
I have the ACC but never lowered the windshield. From what I see, the ACC module is not attached to the windshield. The two wires that you are seeing stays on and will go down with the windshield. Unless you missed another bolt, you may have to use some force to get the windshield down.Thank You! These are excellent step-by-step instructions. However, they don't work for me. I don't know if my issue is only related to people who have the JLU Rubicon Recon or not. Here is my issue. I would appreciate if anyone could help [Thanks in advance].
Please see the attached file...
@Rhinebeck01,@ClusterHead
Your JL, apparently has the ADVANCED Safety group option.. You know, the pricey option you ordered on you JL that gives you Adaptive cruise control, etc..
The instructions / video that you are trying to follow were authored way before the ADVANCED Group option was even made available for the JL..... so that is why those instructions that in their time were very good, but now lacking..
Not sure if anyone here with the ADVANCED Safety Group option on their JL, has dropped their front windshield yet. Hopefully, if there is someone that has, they will post to this thread and tell you how..
In lieu of that... don't bother going to a dealership and asking as my guess is they will be clueless as to how.. Where I would go is your Local Safelite Auto Glass store. I'm sure they will be able to tell you how to get past that box affair on your windshield that is part of your ADVANCE Safety group option.
@ClusterHead@Rhinebeck01,
Thanks for the resonse. That makes sense to me. Ha - I went to my dealer yesterday and you're correct. If I ever figure it out, I will definitely share the info. Thanks, -David Y.
@cns721,I have the ACC but never lowered the windshield. From what I see, the ACC module is not attached to the windshield. The two wires that you are seeing stays on and will go down with the windshield. Unless you missed another bolt, you may have to use some force to get the windshield down.
Hopefully this video will help you out.
@ClusterHead@cns721,
Thanks for linking the video. He made it look so easy. When I tried to do it, I left the freedom panels on. I wonder if they are somehow locking my windshield in place? If not, then I guess there is just an unusual amount of sealer I'll have to wrangle free. I appreciate the quick responses. I will try these recommended steps later this evening, once it cools off a little. I live in an area that is part of the Mojave desert. We hit a record breaking 130 degrees last week. Cheers
@ClusterHead
I think your issue was that you left the Freedom Panels on.... Let us know how you make out..
Also, always be careful with those two wires fastened to the windshield.
When you eventually replace you windshield.... when it gets cracked/damaged, etc., you will need to have your glass place order the specific JL windshield with the 2 wires coming out of it. It is not the same windshield used on non AAA optioned, JL's and JT's.
Also, when you replace the windshield, it will have to be calibrated... cost can be $100+- for calibration.
@ClusterHead
