Fly in drive home question
I think it's two points you are mixing together. But the short answer (for me, anyway) to your question is "every wear surface" in your vehicle needs to be seated. Granted, they put new motors on a dyno before dropping into your new vehicle (that starts the rings/bearings seating) but that process needs to be completed to somewhere between (reference only) 300 and 500 miles. All machined parts have imperfections (high points) that need to be worn down, or seated. That includes the engine, tranny, transfer case, rear ends, brakes, etc. Hell, I don't even fart in my new seat for the first 500 miles, but I probably should, at least little ones.
My other point is that I do not, nor should anyone else, "baby" their new vehicle. Drive it like you stole it, but only up to around 4,000 rpm. There is plenty of data from torn down engines that show improper wear of parts that were pushed above that threshold during the break-in. 4,000 rpm is a more important threshold (for me) than how the vehicle is driven during that period. They are two separate points.
Anyway, 'nuff said. It's a great subtle point you bring up. I hope you get what I'm trying so inadequately to say.
With regard to engines, I'm more of the belief that engines will either be put together with the right characteristics of fit and finish or not. In many years past, the term "blueprinted" was common amongst racers. In my youth, I worked in a race engine shop as a machinist. We would strive to achieve what vehicle manufacturers do better day in and day out today. It's all because of the more precise machining technology used throughout the automotive manufacturing industry. No manufacturer uses those old planers and shapers that the smallblock and big block chevy was originally made on. But, even those old "blueprinted" racing dinosaurs would get a short break-in for the cams and hit the track. A bearing is either right or not. If there's metal to metal contact in a rod or main bearing, it's likely not going to go the distance. Fortunately, that condition is seldom seen today.
With regard to rpm, any limitation during break-in should be about piston velocity, or more specifically, about the ring/bore velocity. That's a function of the stroke length x the rpm. Small engines have lower piston velocities.
LSJKU
Hill Country
2025 JL Rubicon, 2019 Raptor SCAB
doodlebug
Yes sir, understood and fully agree. With respect to piston velocities, you are spot on. I just thought it was more easily conveyed to the non-techie as a general rpm term. But you are absolutely correct.
I come from the old school days myself. I didn't do automotive machining but as a young amateur, I did build a few engines. And a "balanced and blueprinted" engine was the gold standard. Anybody serious about performance was doing it back then. Shaving heads and porting & polishing too.
In 1983 bought an AMC General 401 out of a '71 Matador for $50 (whole car), had it "B&B'd" when I rebuilt it, and tucked it and a T700 in my first Jeep, a '74 CJ5. Why? Because I could. Everyone I hung with was doing it, I was stupid young and had the money. Would I do it again today? Probably not. But those days are where my love of V8s in Jeeps originated. Cubic inches was the basic answer to most ills back then. And that was not a bad thing.
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
I dont care what Mopar on anyone says, its my new Jeep and I am farting in it all I want from day 0
Truth. I farted in someone else's jeep.
brandofamily
Anthony
illinois
2015 & 2016 JKU
So the consensus is there is no consensus except for the higher RPM blips along the way and no cruise control. I’ve got 60 miles on it now before I hit road home. Want to avoid highways but roads thru Appalachian Mountains on the non-highway roads kinda freak me out. Hell I don’t like the ones on the interstate either. I guess I’ll do some 2500rpm stretches before heading out tomorrow then hit the road and not use cruise control. 1/2 the time construction will slow me until I get thru mountains anyway.
X35
PA
2025 Wrangler Willys XR
Dude, don’t be scared. Hit every one of the Appalachian road side bars along the way and it’ll be a good trip 😉👊🏼🤷🏻‍♂️👊🏼
Nitehawk92
Vandalia, Ohio
23 JLU Reign Rubicon 14 Mazda, 22 Hyundia Santa Fe
Retired Air Force Current Civil Service Civilian.
I made a 330 mile trip home after picking up my Jeep. I did the 1st 100 miles on back roads and then hit the interstate for the next hundred, and then traffic the rest of the way. If you wanna be safe, don't just immediately hit the interstate and keep the cruise on the same speed for hours on end to play it safe...
brandofamily
Anthony
illinois
2015 & 2016 JKU
No cruise control. I’ll have 100 miles or so on it before I hit highway. Thanks.
Not so much high rpm blips as mid rpm, high throttle.
brandofamily
Anthony
illinois
2015 & 2016 JKU
Gotcha. I did say “higher” not “high” though.
From ur prev post this needs to occur before highway also:
“Use the manual mode, for an auto transmission, above say something like 35 mph or higher, select a gear that gets the rpm around 2500, then accelerate at full throttle to 4500-5000 rpm, upshift and repeat. A few cycles like this, then easy driving to cool down, then repeat.”
LSJKU
Hill Country
doodlebug
I might doing a fly-n-drive, myself, this weekend if everything works out.
LSJKU
Hill Country
doodlebug
Anthony, I don't think i would run it up to 5,000rpm. That's a bit excessive on a new engine for all the reasons previously discussed. Vary your speeds and rpms as you suggest, but honor the top rpm at around the 4,000 suggested max. At least for the drive home. I think that's what Mr. Cowpony means by "mid rpm." I did that on my 1,000mile trip home from Denver. It's pretty simple in a standard though, just a lot of upshifting and downshifting at different highway speeds along the way.
It's all about piston velocity. What was a prudent limit for an engine with a 3.5" stroke is different for one with a shorter stroke. But, yes, about 4000-4500 would be prudent.
