Drivers cluster display flashes when using navigation... and other issues
ag4ever
‘82 CJ-8, ‘82 CJ-8, ‘83 CJ-8, ‘26 Moab 392
2wd is also possible with the 392s but it needs a Taser. With the price of premium up here (over $2 per liter) I think I would be looking at dropping consumption a bit. lol
While it is possible to force 2WD with a taser, it has been proven that doing so uses the canbus and when the canbus is overloaded it defaults back to 4H Auto for split seconds causing odd driving dynamics. If you have not also installed the FAD components it will cause a very brief engage / disengage action on the front axle. Just something to consider on the 392.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Ya, I dont have a Taser or a 392, but good info for those that do.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Every time I see this thread title on the list it makes me chuckle to myself a little bit. When I see "Flashing Dasher" all I can think of is a door dasher at the door with more than food to offer.
ASSFROW
Gary
Mt. Airy, MD
2024 Rubi X
Oh if I'm your Dasher Flasher you'll have more than a little bit to chuckle about........
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
I DIDN"T ORDER THE SAUSAGE!!!
alphawolff
california
2021 JLU
On the 4xe, if you want maximum performance you must be in 4HI Auto. This is a full time AWD mode with automatic clutch based engagement of the front axle.
If you are in 2HI, you will have significant performance penalties.
When I had my 4xe that was the mode I drove in exclusively while on pavement. When on dirt it was 4HI Part or 4LO.
With my MOAB, I have no option, it is 4HI Auto with no provision for 2HI. I am just fine with that.
for any vehicle that's equipped with it'd i'd also suggest cruising around in 4h auto. it helps off the line and you definitely notice the additional torque. if you plan on going off road be sure to swap it into 4h part time as the clutch packs wear quickly if you're relying on 4h auto with loose terrain. this is especially true in the 392
Earl24Rubi
Earl24Rubi
Maryland
2024 4xe Rubicon
Unfortunately the issue has returned. Replacing the radio did not resolve
X35
PA
2025 Wrangler Willys XR
Can we fix the tread title? Flashing dasher made it this far? We talking about a gauge cluster or a reindeer here 🤷🏻‍♂️🤣👊🏼🍻
Earl24Rubi
Earl24Rubi
Maryland
2024 4xe Rubicon
I fought it was humorous and gave me relief from my frustrations. I will see if I can accolade
  • Like
Reactions: X35
