Fender flare question
LSguy
Ohio
2021 Willys
Hey guys, I broke one of my factory flares on my JL, and I found a set of Deegan 38 tubular flares super cheap on Extreme Terrain. These flares have 3 LED marker lights on them. With the location of these lights, would it be legal to use them as turn signals, or would I need to add in a standalone turn signal light on the front?
https://www.extremeterrain.com/deeg...er-flares-with-led-marker-lights-j131663.html
Thanks
Jeep Wrangler JL Fender flare question J131663_alt1
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
It's hard to tell from the picture but it depends on whether the light is visible to the front. If not, then it's not legal in California. Other states laws are probably the same in this regard.
LSguy
LSguy
Ohio
2021 Willys
The Ohio law on this confuses me a bit.
Jeep Wrangler JL Fender flare question SmartSelect_20210307-150827_Firefox
I can't tell if it says from the front, rear, and side, or if it is saying from the front, viewed from the direction you are turning. If it's directly center front I doubt you could see them, but if it's from the front from the side you are turning you may be able to.
Dan M.
Albany NY
2020 sport (2 door)
I can' t say for sure if they would be legal, but I would be willing to bet you will get pulled over at least a few times if you install them as is. Not sure if it would be worth it.
LSguy
LSguy
Ohio
2021 Willys
Maybe I'll toss a little led on the front and just make them all turn signals. Anybody have placement area ideas?
JeepU4IA
Rod
Los Angeles
The Ohio statute you posted is not ambiguous. The light has to be visible "to the front" and visible to 300 feet in daylight.
operator22
Bob
Tampa, Florida
2021 JLU Willys
I know you only need one but have a set of lo-line textured flares available. Includes indicator lights. $100. I’m in Tampa FL.
