Fender Chop - Replacement Fender Trim Options?
keg392
Dallas, TX
'22 JLUR 392 XR
I'm looking into doing a fender chop on my Rubicon. I plan just to cut the plastic trim to keep the molding, but worried that if I screw it up, or looks bad, I'm stuck with it. My question is:
Are there any aftermarket or OEM(ish) options to put a trim piece back onto the stock fender in the event the plastic molding looks like hell when you install a chop kit?? Looks like the factory plastic trim comes with the fender itself, but is there anything else?
I don't want to have the edges of the fender exposed, so leaving them bare isn't something I want.
Grayhound
Michigan
Jlurd
When I did the chop I accepted that I may have to buy all new fenders of it didn’t go the way I had planned. Thankfully the chop worked out for me.
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_2657
keg392
keg392
Dallas, TX
'22 JLUR 392 XR
Chop looks good. What process / tools did you use for a clean cut?
Grayhound
Michigan
Jlurd
I used simple hand tools. A little rotary took did the cutting for me.
I started on the passenger side as I had damaged that fender, I removed that side when I did the chop. It went well.
for drivers side I left the fender in and the chop was a lot faster.
i kept my inner liners. So if you can see in the pic I had to figure out a cut that looks okay. I decided to use the bottom of the light as my liner to cut.
all in all I really like it. I was running halogen headlights and didn’t like the temp mismatch of color afterwards so I went to oculus projector headlights for the color match.
greige
Robert
2023 farout
I am interested in what you are trying to accomplish. Previously, I read chop as a means to get more clearance in the fender well. Are you just trying to replace the DRL, or are you trying to get more clearance? If the latter, after watching a few videos, I would be surprised if you can keep the trim on the edge of the fender while removing the liner inside the fender. Obviously you could use a tool to cut and separate the trim from the liner, but it seems like the trim would lose a big part of its anchor and become floppy.
keg392
keg392
Dallas, TX
'22 JLUR 392 XR
I like the way your mind works. You are correct, I'm not trying to gain clearance as I already have plenty. My goal is to get a slimmer DRL and get that giant plastic housing out of the way up front that hangs down.
I'm all ears if you've got some different ideas.
greige
Robert
2023 farout
I think you're on the same path as Grayhound above which sounds like a factory chop.
Good luck.
svc707
Steven
Vacaville,ca
23 JLR, 21 JTM, '23 4RNR
Fully gutted my JT the JL I just removed liner and trimmed for the chop.
Made my own stand-off support for the fully gutted and separated JT flares.
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_5238
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_5724
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_5725
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_5726
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_5727
Ney Kerestegian
Ney
Chile
JLUR 2020 3.6L
Do I get more clearance just by removing the inner fenders? because my tires are rubbing in the inner fenders when doing a full turn and hitting a small bump.
broncoguy
Guy
Aptos, CA
1970 Ford Bronco, 2018 JLUR
Realtor
@svc707 When you did this on your JL do you gain much clearance for up travel? Or was it just for the look?
I am looking to gain a bit more up travel as my tires rub the upper inner fender liners but not sure I want to go full gut on the fenders. Was thinking of just adding inner fender liners and doing what you did here. I kinda like the stock fender look but looking for some more clearance.
Thanks!
svc707
Steven
Vacaville,ca
Thanks!
You do gain because you’re removing the plastic which still has some hollow gap to it.
broncoguy
Guy
Aptos, CA
Realtor
Thanks, I also just found this video which shows removing some of that plastic structure but leaves the trim which keeps the finished factory look. I think I'm gonna give that a go.
svc707
Steven
Vacaville,ca
Yeah just take a blade to it and trim as you go. I don’t think I even took the flare off
svc707
Steven
Vacaville,ca
I just did another Gladiator today with the Metalcloak Gutz delete
I also installed the Metalcloak inner liners
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_7977
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_7979
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_7982
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_7984
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_7985
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_7998
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_7992
Jeep Wrangler JL Fender Chop - Replacement Fender Trim Options? IMG_7996
