fault codes
Ripsaw502
Millersport, Ohio
2018 WRANGLER UNLIMITED RUBICON 4X4
Dump truck Driver
76 fault codes need help.Dealership well i'll be nice .
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
They're nearly all "lost communication" or "screwed up data" codes. You could have an overall power problem.
Are you still on the original battery?
Ripsaw502
Ripsaw502
Millersport, Ohio
Dump truck Driver
changed both batteries without aux power hookup dealership said this messed with computer . They reset that, wiped all codes good to go right Nope all good all day out to dinner no power steering track control abs sway bar windshield wipers come on almost wreck not happy
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
That many codes at once could also be a failed PCM.
If the dealer reset the PCM that would not necessarily fix it.
Did you not have any codes before the battery swap?
Valpo Jeep
Doug
Valparaiso IN
15 Mas Ghibli, 18 JLU, 05 Gulfstream RV
When you get that many codes step 1 is to clear all of them and see what comes back. Could also point to a power supply problem. Might need a new battery
SmyJeep
Shawna
Stouffville
Wrangler 2020 Sahara Unlimited
I am experiencing this exact issue now and this will be by 4th trip back to the dealer. Anybody know how this turned out in the end?
Grooster
Greg
Wichita, Kansas
2023 Unlimited Rubicon, 2016 Cherokee Latitude
IT Business Solutions Director
check the green can bus connection behind the glove box. known to cause these problems. worth a look.
