Falcon 1.1 vs Fox 2.0
18punkn
2018 JLU
Trying to decide between these 2 shock. Its for a 18 JLU with 2.5 spacer lift. Will mostly be on road with the occasional off road adventure. Does anyone have any input between the 2?
TeraFlex
TeraFlex
teraflex.com
JL, JT, JK
The only thing that the Falcon 1.1 and Fox 2.0 are going have in common is that they're both a rebuildable monotube shock.
Here's a neat video that will help explain them better
18punkn
2018 JLU
Thank you for the reply! How would you compare the ride of the 1.1 vs the 2.1?
DavidArmen
Los Angeles, CA
2021 JLUR
I would recommend the fox2.0
That is what I run with my dynatrac Endurosport lift and it’s great. Everyone says falcons are too stiff so it’s a preference thing but I love the fox2.0s, especially when they’re tuned for the specific ride.
Jeep Wrangler JL Falcon 1.1 vs Fox 2.0 01863192-5C2D-4FB6-98FD-4141D22D29F3
TeraFlex
TeraFlex
teraflex.com
JL, JT, JK
Great question. The Falcon 2.1's valving is more aggressively tuned for higher dampening rates, where as the Falcon 1.1's are tuned on the less aggressive side for more on road compliancy. The 2.1's will ride a bit firmer as a result.
18punkn
2018 JLU
I noticed the new 2.1 are able to be set between soft and firm. is the soft setting still a firmer feel then the 1.1?
TeraFlex
TeraFlex
teraflex.com
JL, JT, JK
According to one of our main Falcon techs, the 1.1's are slightly softer than the 2.1's in the SP2 "soft" mode.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
What are the compressed/extended lengths for the 1.1s?
18punkn
2018 JLU
I see the 1.1 are listed for 2-3.5" of lift. I currently have 2.5" front and 1.5" rear spacers, running the stock shocks with extenders. If I remove the extenders, will these work or will they be too long in the rear?
TeraFlex
TeraFlex
teraflex.com
JL, JT, JK
The front come in at 27.5 extended 17.9 compressed. The rear's come in at 29 extended and 18.7 compressed.
That shouldn't be an issue, past the 1.5 inches of lift in the rear you'll be okay.
GATORB8
CLT NC
Thanks!
18punkn
2018 JLU
Thank you for your help! Ordered them today and can’t wait to try them out
jeepdabest
Bobby
Arizona
2019 JL Sahara
Fox 2.0 Stabilizer cured the Death Wobble and removed the slop
