Evo Mfg extreme coil spring bow
ros
NJ
JLUR
I recently purchased an evo lift kit from northridge4x4. After the install, I noticed the passenger front spring had a massive rearward bow to it almost touching the shock.
Jeep Wrangler JL Evo Mfg extreme coil spring bow IMG_3332
I checked the driver front, no problem there. I then checked the part number on the spring to see if it was on the correct side and checked the make sure it was seated correctly on the top and bottom isolators, everything checked out.
Jeep Wrangler JL Evo Mfg extreme coil spring bow IMG_3333
Jeep Wrangler JL Evo Mfg extreme coil spring bow IMG_3335
I then emailed northridge4x4 support to see what my options were. After a few email back and forth, the suggested I use a drivers side spring isolator ( Mopar Part #: 68342245AB ) on the passenger side spring where I'm having the problem. Ive personally never heard of this and it was also never mentioned in the evo instructions. Is this a legitimate fix for spring bow or is this a quick suggestion just to get me of of their back? I'm not sure whether I should actually try that and potentially waste my time or just ditch northridge all together and buy a new set of coils from a different site.
Roky
Roky
Can I see pic of drivers side ?
Roky
Roky
Being that the drivers side looks good, then my best guess is that it’s an isolator issue. You can get some RK bottom isolators for around 30.00. They correct the problem most of the time. I have to ask, even though it’s probably not the case, but are the control arms the same length side to side (passenger to driver).
ros
ros
NJ
JLUR
good question.. hahah ill have to go out and measure in the morning but thank you for the help ill have to try new isolators.
VolvDL
CO
18 JLUR / 08 F350
I have an EVO overland lift, and both of my front springs bowed. I put Rancho spring perches/isolators (probably incorrectly mixing terms) on and the springs were immediately straight.
plex
Cincinnati, OH
I am still baffled how EVO mfg can get customers given their horrible qualities, is it just because they sponsoring couple of youtubers?
40”JLURD
Ross
Southern California
Bad Mother Fucker
Yes probably and unfortunately.
I spent way too much on Evo trash. None of it is what they claim it is
For example the springs on my “Diesel Specific” Coilover lift probably would be barley adequate for a bone stock pentastar - surely way under for a heavily armored diesel.
Now with only 6k miles on their most expensive Coilover lift I am looking at replacing all 8 springs with Eibach ones. Not cheap… it’s gonna run me about $900 just in parts to replace some shit that I just bought and should’ve lasted for many years.
All because Evo does not spring or valve any of their shit correctly.
Thankfully @AccuTunedJL / @AccuTune Offroad has the knowledge to fix all these Evo blunders… within constraints of what Evo did originally of course…
There’s a reason EVO isn’t even on this forum. That alone should speak volumes about them and their products and customer service….
ros
ros
NJ
JLUR
i went with rock krawler isolators but never got a chance to throw them on. if they dont work for me ill have to give the rancho's a shot. thank you
ros
ros
NJ
JLUR
i bought their coils because you can buy the kings valved for them. that bit me in the ass because now my passenger front king 2.5 has a long gouge down the side were the spring hits it.
SDhobbs
Del Mar, CA
2020 JLUR
I did the same with my 3.5 EVO Enforcer lift, Rancho spring isolators fixed the bowed spring issue for me too. I had heard EVO was now including the spring isolators with their lift kits, guess not.
SuperUltraMan
North Carolina
JT Gladiator Rubicon, JL Wrangler Rubicon
Nope. Rancho isolators didn’t fix my bowed springs.
I have the 6.5” plush coils and they bowed so badly forwards.
My passenger side was made to bow more rearward but now inboard bowed, after cutting the rear of the Rancho isolator.
Driver side spring bows back and hits my trackbar reinforcement bracket even when driving over very small bumps.
Can’t cut the Rancho isolator on that side because it already slopes the way I would need.
Tired of this.
EVO said,”One out of every 10 or 12 spring sets will bow. It’s normal. Add isolator pads and more caster.”
Seriously?!
…Contacting Notthridge4x4 hoping they can help.
SuperUltraMan
North Carolina
Is this happening with shorter springs?
4.5” EVO Plush coils?
Maybe I can swap to those with a spacer.
