Jebiruph
It doesn't look like an electrical issue, have you hooked up a code scanner to look for trouble codes?14.3, same as when normal.
I would say if it reads 14.3 all the time even after coming off a charge then you likely have a battery issue, Jerry would know more.14.3, same as when normal.
I checked for codes last week and there was none. However, yesterday the CEL came on, and went back off before I got home. That code was PO365, which I believe to be a camshaft position sensor error. It hasn't been back on though.It doesn't look like an electrical issue, have you hooked up a code scanner to look for trouble codes?
A camshaft position sensor failure could certainly impact performance which could trigger the other issues. You need to get it checked out by a dealer.I checked for codes last week and there was none. However, yesterday the CEL came on, and went back off before I got home. That code was PO365, which I believe to be a camshaft position sensor error. It hasn't been back on though.
